Question about Home
My new triton shower keeps dripping when switched off
My electric shower keeps dripping when switched off tried removing head & emptying it,also leaving it hanging low to drain off,but still carries on dripping 5 mins later..
The actual cause of this will depend on what type of shower unit this relates to - ie Mixer Valve, Electric Shower etc.
Generally though if the unit is new and therefore under the manufacturers warranty period the best course of action would be to contact Triton Service Dept direct - Tel 0844 980 0750 where a in warranty service visit may be arranged for you.
Posted on Jul 28, 2010
Testimonial: "thanks will do !!!!"
I have a triton t100xr shower as soon I press the on switch the power keeps tripping off, please can you help?
Chances the trip switch is not high enough,as in it may need a higher amp than what has been installed.You should be able to check this out by looking at the fuse board.If memory serves me right it should be 40 amp.Check this out in the paperwork that came with the shower. If not contact Triton, they are most helpful & easy to deal with. Their number can be got on Triton site. Be VERY careful when touching any wiring either @ the fuse board or the shower.
Apr 24, 2014 | Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Theres only a low flow of water coming out of the shower.
remove the head and make sure you have a good flow to the head if you do look to see if a plug needed to be removed before installation if their isn't return the product
Jul 06, 2012 | Home
I have a drip, drip, drip from my shower head on my triton t90x can you please advise. thank you
A shower head will drip for a period of time but I will assume that it is dripping continually. Servicing the Mixing Valve is what is needed to fix the continual drip. there are several 'O' rings washers that eventually wear down causing problems. These parts are serviceable and kits with instructions can be purchased at plumbing shops, DIY Stores, Hardware Stores. I hope this has helped thanks for using FIXYA. Good luck and have a great day. Jeff
Apr 07, 2010 | Home
Triton ivory 2 drips from shower hose when switched off any ideas or does it all need replacing thanks
heat from my shower keeps changing temperature, it will not hold the same temperature for very long...any tips ?
Mar 20, 2010 | Grohe 25 597 Talia Tub Filler w/Personal...
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Sep 25, 2009 | Delta & Single Handle Shower Faucet
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
MY Triton T90si electric shower continues to run when it is turned off. It is not fully on , but water keeps coming from the shower head evev when the electric isolation swithc has been turned off. Also it...
Most conventional showers have brass seats or rubber seats that can deteriorate over time. these will leak or dribble and not maintain your temp.. Rubber and brass seats are a fairly common and easy replacement. It sure beats trying to rip out a shower valve.
Jul 11, 2008 | Heating & Cooling
Home Logo
1,320 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
