Question about Craftsman Mulch Kit for 54" Deck
What size blades do I need to buy for my 54 inch craftsman? I want mulching blades and i don't want to buy the kit do to it's poor ratings and problems
  • 49 Answers
SOURCE: craftsman snow blade install instructions
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Posted on Feb 06, 2009
  • 79 Answers
SOURCE: Craftsman GT5000: Dies when switch is pulled to engage blades
Hi
Check for burnt fuse behind dash. If no burnt fuses check if getting power to magnetic clutch mounted on bottom of engine crankshaft. Make sure wires are not broken by magnetic clutch. Make sure the safety seat switch is working. Make sure you are sitting on the seat when you try to engage the blades. If that does not work try pushing and wiggling the seat sensor. Check make sure wire is attached to safety switch under seat.
Posted on Apr 08, 2009
  • 10865 Answers
SOURCE: What is the spark plug model number for craftsman YS4500 lawn mow
go to any auto parts store with your model info as they have a book which will tell them which spark plug is best for u.
Posted on Apr 16, 2009
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
I canot get a bagger kit for the 54inch cut lawn tractor in UK, can a 48, bagger be fitted and altered to fit which I can get in the UK
I have never seen a catcher for this size of deck, Husqvarna do not offer one, i am sure the deck aperture is different from the 48" machine, if the catcher is available in the US, would they just supply the upper and lower chutes? the 52" deck produces a vast amount of grass, so will fill the boxes very quickly, you would spend more time going back to the dumping area than actually mowing, mulching would be a much better option, if you have to collect would a tow sweeper not be better, it holds more grass, and you would not have issues with poor draught, and grass blocking in the chute ( a big problem with noise compliant machines, and damp grass , and side ejection )
Oct 10, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have 11 years old Murray (42 inch deck). After deck adjustment still leaves uncut portion of the grass between blades. Should I exchange the blades (I have not done it for many years, but I sharpened...
On a two blade deck, such as yours, there is generally an overlap between the cutting coverage of the blades so that you do not leave a mohawk. This does not work well on turns however, and the sharper the turn, the more grass is left. Overcoming that issue brings you up to a 3 blade deck. If your mower is leaving a strip of uncut grass while cutting in a straight line, somehow you are running blades for a smaller deck, thus there is no overlap. The mandrels are offset, one slightly in front of the other so that the blades do not hit each other. I would measure under the deck and see how long a blade could be and still fit within the deck and not strike the other blade, then ask a parts store to sell you something longer than what you have now.
Oct 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
This is my second mower. First one damaged after hitting a rock. My replacement mower will not discharge grass out of the side discharge. I have the mulching attachment in and the discharge chute as...
it could be a low lift blade on it. try to get gator blade for mulching..... or a high lift blade. lol, size does matter!!! this may fix the issue. there is so many blades out there now, experiment till you find what your looking 4......
Sep 21, 2010 | Worx 19-Inch 24 Volt 17 Ah Mulch/Bag/Side...
What type mulch kit do I get. One says stamped deck zoom 34
Mulch kits are a waste of money. If you have high lift mulching blades you keep the grass in the deck long enough to do the desired cutting. Open the deflector and block it open with a bungee strap and let the blades spread the grass,so you get no streaking or wind rowing.
CAUTION
Always discharge away from PEOPLE and Buildings and automobiles. I cut an acre here that looks like any golf course with NO MULCHING KIT. MULCHING BLADES ONLY.
Oct 19, 2009 | Garden
I would like to replace the mulching blades on my Sears Craftsman riding mower with regular cutting blades. I can find plenty of sources for new mulching blades, but not cutting blades. My mower is a model...
The straight blade for the 42 inch mower is 138971.They cut better and are easier to sharpen and you will need them if you use a gass catcher. If you do not want to use sears for parts you may be able to find good deals on ebay.
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
May 17, 2009 | Craftsman Garden
Craftsman Mulch Kit for 54" Deck Logo
22 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
