Question about GE GSL25JFPBS Side by Side Refrigerator
Icemaker dispenses crushed ice when you select cubed ice
You get crushed ice on both settings, cubed or crushed.
  • GE Master
  • 1,606 Answers
GE has a problem with the flap on the door which lets the ice out , not closing due to a rusted solenoid behind the panel . If this flap does not close , frost will get inside the ice bin , not letting the bin flap open to let cubed use come thru, only crushed . You can defrost the ice bin front and replace the door flap solenoid easily . If this is the problem , repost about replaceing the flap solenoid for further instructions if needed .
Posted on Jul 28, 2010
    Genius:
  • 1,478 Answers
A faulty ice maker thermostat, a choked up water line or a defective water inlet valve could be the reason your ice maker is unable to produce proper ice cubes. There will be water line behind the refrigerator which you need to check for proper water flow. In case of water not flowing properly through this pipe, clean or replace it if necessary. Inspect the water inlet valve and get it changed if it has broken down. Set you freezer temperature not more than 8 degree Fahrenheit, to ensure a correct ice formation cycle.
If you take out the bin with the ice in it, right behind it there should be a very small box with a lever in it. It doesn't exactly look like a lever, but a piece of plastic that is in the little box, and it slides up and down. It gets stuck down or up (I forget which). You can just push it with your fingers, usually. Push it up and down a few times to unfreeze it.
Take care.
Posted on Jul 27, 2010
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 31, 2009
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
My Frigidaire Electrolux refrigerator ice dispenser is dispensing chrushed ice regardless of whether the ''crush'' or ''cube'' option is selected. The icemaker is working. How to diagnose the problem? The...
Open the freezer door. Pull the ice bin OUT and then push it back IN until it locks in place. They will "jump the track" at times,causing crushed ice regardless of the settings. Look under the ice bin. You will see a metal rod it goes inside a yoke in the back of the freezer. Make sure it is inside,not under or over the yoke.
Oct 08, 2009 | Electrolux Refrigerators
Our GE Monogram Icemaker will only dispense crushed ice
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Aug 29, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice cubes will not dispense, but crushed ice will. GE Profile TPX24PRYA
If the auger motor turns in either setting we know that the auger motor is OK, and if it does not turn in both crushed and cubes that leaves a problem with the WR55X129 time delay, which is the part that you switch to go from cubes to crushed to water.
Dec 06, 2008 | Refrigerators
MZD2666KES will no longer crush ice. The dispenser light is on however it dispenses cubes only.
Did you pull the icemaker out and then have the problem?
If so, select 'Crush' and Slide the ice maker out and slide back in. You will notice a rod on the end (bottom left of the unit) slides into a little cubicle that moves up and down to provide either crushed or cubed.
May 21, 2008 | Maytag Refrigerators
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice.  In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed.  Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out!  Thanks to Jake!
Apr 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
211 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
