Question about Carrier 38CKC036 Air Conditioner
Box on the wall. Push buttons
On the box attached to the wall. Has push buttons. One button is marked "mode" My question is: what is the mode button used for?
    Scholar:
  • 66 Answers
Mode will be heat, cool, or automatic. cool will show a snow flake flashing. Heat will show a flame and auto will switch from heat or cool by itself. Usually the auto feature does not work well as one is unable to set the heat and air where they are comfortable on both
Posted on Jul 28, 2010
My Sears Garage Door opener will not close using the clicker or the external pin pad.The only way to close it is by using the push button that is in the house.The garage is attached to the house.
Your sensors have to be reprogrammed. I had one like yours and to reprogram I had to get some one to push a button on the ceiling box as well push the sensor box at the same time that is out side. . I hope you have your instruction book as that was how I knew what to do. There might be instructions on your out fit that is on the ceiling over your car.
May 11, 2018 | Building Materials
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
My mx android tv box won't switch on to home page or return there so I can't get to android side I don't know if I hit always instead of just once Mark
On your box is a reset button.push in with a tooth pick. Release unplug power connect. Then push reset button again wait 10 seconds while holding reset button re plug right hand power cord. Release button and wait. Information box will appear click top section to reset. This should resolve problem. If not you will repeat when screen appears scroll down to reset to factory settings. Follow steps to connect again. I hope this works. Also do a search on youtube.
Feb 01, 2015 | Televison & Video
Not able to enter program mode
You need to remove the conrol drawer.Open the door,look at the top and there will be 2 screws,remove the screws then slide the control box toward you.You will see 2 circuit boards,the one to the right is the control board.You will see 2 white buttons marked prog and select.Hold the prog button in and the on button.You should now be in the program mode.
Mar 31, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
TV & DVD HookUp (No Box) Can't get picture
As far as I know, my Go Video machine when there was no box involved...
The cable came from the wall to the IN of the Go Video box. Then another cable coming from the OUT of the video box and to the IN to the TV. TV should be on channel 3. As far as I can remember, I don't need to push the TV/VCR button, but instead, have to channel down to below channel 2 on the TV to the LINE/INPUT selection. Once you go there, and the Go-Video machine is on, you should be able to see a clear picture.
You'll push the TV/VCR button if you want to toggle back and forth from the VCR picture to the TV picture (which will be technically blank since it's on the 'line input selection.)
Hope that helps.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
Remote not workin
what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
· Any of the system components (room unit or relay box) are replaced
· HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
· Interference with the RF signal has caused a communication failure
During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
hope this is helpful
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Need a wiring diagram for installing a EJ500C in place of a 3-way
Locate the COMMON wire
connected to first old switch.
It might be attached to a different
colored screw, or find
markings on old switch.
Connect BLACK wire from
switch timer to COMMON
wire, using a twist connector.
Connect the other two wires from the old switch to either the
BLUE and RED wires from the switch timer.
Connect the ground wire from the box to the BARE COPPER
wire on the switch timer. If there is no ground wire, ground the
switch timer to the box. If the box is plastic, connect the bare
copper wire to ground as supplied or contact an electrician.
Locate the COMMON on the second old switch of the 3-way pair.
Connect jumper wire (supplied) from the COMMON terminal
to either of the other terminals on the remote 3-way switch.
Make sure all twist connectors are tight.
Tuck wires into wall boxes leaving room for the devices.
Mount the devices into the wall boxes, then install the wall plates.
Turn power back on at the service panel.
Make sure the switch timer displays “MAN” mode. Do the following
test with the remote switch in each of its 2 positions:
Press the NEXT ON/OFF button on the switch timer several
times. Each time that you push the
NEXT ON/OFF button, the
switch controlled light or device (the “load”) should turn on
or off. If so, proceed to Section 3.
If the timer display changes between ON and OFF but the
load does not operate, re-check your wiring and make sure
the load is functional.
load only operates when the
remote switch is in one of
its 2 positions, you need to
turn off the power at the service panel, change the jumper
wire to the other terminal. Then turn power back on at the
service panel and repeat. good luck
Jan 20, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
No communication between remote controllers and main box
Push the X sign on the controller when its turned on then push the wi-fi button on the console its the small button in the front and push the wi-fi button on the controller too its the smallest button on top close to the rl trigger !!
Nov 07, 2008 | Microsoft Xbox 360 Console
Carrier 38CKC036 Air Conditioner Logo
80 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
