Question about Car Audio & Video
I have a Phase Linear UV7i . everything turns, Except theres "NO SOUND" and the Screen Is " BLUE" and you cant see anything? Whats wrong with it? Is it bad and should i throw awat? HOW CAN I FIX IT? pLEASE hELP
  • 532 Answers
Here is what you all need to do. In order to bypass the ebrake switches blue preventing screen you must take out the head unit and splice(tie in) the PINK park wire to the BLACK ground wire. Trust it works just fine after doing so, so you will not have to worry about the horrid blue screen no more. Or
) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press system SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional TV's, its #$%^&* damn hard because you can't see the settings your changing.
Thanks for contacting Fixya.
Posted on Jul 27, 2010
Testimonial: "thanx for the info!"
My UV7i just opens and closes as it pleases
Some loose connection on the LCD panel to the device, or inside the LCD, by a certain vibration the monitor seems to get like a christmas lights one on/off..
you better bring it to a certain service technician to provide through test on your device.
thanks
Feb 23, 2008 | Phase Linear UDV9010 Car DVD Player
I have the phase linear UV7i I was trying to put in the overide
reset it,try with out the remote and change the remote battery,put in dvd wait for the blue screen,then press stop 2x then enter 1264 then,if you have a up,down,l/r control on the deck press down 1x then press play,you dont even have to use the ground wire then go to the rest, when you can see the menu,i dont know if it will work but u can give it a try
Jun 18, 2009 | Phase Linear UDV9010 Car DVD Player
How can i watch dvd while i drive?
its very sample. you will insert a DVD and everything will be start and going automaticly.
May 29, 2009 | Phase Linear UDV9010 Car DVD Player
Wiring uv7i
you can use the deck without a remote, the only thing is you cant go into the system without the codes. there is a sequence code you must enter to disable it. there are a couple of videos on youtube but none for the uv7i. trust me, i 've been there on and off since the summertime. i am not sure if the sequence works due to me not hooking it up to external monitors but you can disable the blue screen with a on/off switch...only problem is, you'll have to do it everytime you turn your car on. here's what you do....
buy a on/off switch(radio shack $3)
hook the pink wire to one part of the switch-the other to the negative ground
put a dvd in(from what i hear, it must be store brought), wait unntil the blue screen comes up
turn the switch off...wait two seconds/turn on...wait two seconds/turn off...wait two seconds and turn back on. the blue screen is gone and video is on. ifyou still need the diagram, i'll scan mine for you.
Nov 09, 2008 | Phase Linear UDV9010 Car DVD Player
Phase linear UV7I
I Need Phase Linear uv7i Owners Man. Also Vol. Control Goes Up As You Turn It Down. Repairs??? C/D Dvd Not Working! Help!
May 27, 2008 | Car Audio & Video
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
Car Audio & Video Logo
173 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
