I have a Phase Linear Uv7i It turns on but theres "NO SOUND" and the screen is just" BLUE". is the stereo bAd? What do you think is the Problem ? And how can i FIX IT? PLease HELP
  • po21409 Jul 27, 2010
    I have a phase Liniar uv7i, the stereo turn on all buttons turn on, but theres NO SOUND and the screen is just BLUE and u cant see anything? WHATS WRONG WITH IT? HOW CAN I FIX IT?
    President:
  • 1,099 Answers
Hi there. Are you familiar with board level repair for such products ? Your problem is most likely hardware. Either some of the final output transistors are fried, or it's a dsp problem, a regulator, a diode, a transistor in the circuit.. it could be a lot of things. But if everything was working fine and it quit someday without a change in the system's setup, it really looks like an hardware issue !
Do you have a way in the manual, that sets factory defaults, a kind of reset ? A lot of such units do have that. Try to unplug/interchange speakers as well, a shorted speaker could make the amp go nuts as well.
Hope this helps.....
Posted on Jul 27, 2010
Testimonial: "thanx for your help!!"
    Top Expert:
  • Audio Player... Master
  • 77,529 Answers
Yes something in the recievers circuit has failed,what that might be will take a diagnosis from an electronics repair facility, Radio Shack can give you an estimate to repair it, but they will need tosend it out to one of their contract facilities for that.
Testimonial: "thanx for your help!"
  • yadayada
    yadayada Jul 27, 2010
    u can't fix it unless you are equipped with the test gear and the training.
My UV7i just opens and closes as it pleases
Some loose connection on the LCD panel to the device, or inside the LCD, by a certain vibration the monitor seems to get like a christmas lights one on/off..
you better bring it to a certain service technician to provide through test on your device.
thanks
Feb 23, 2008 | Phase Linear UDV9010 Car DVD Player
I have the phase linear UV7i I was trying to put in the overide
reset it,try with out the remote and change the remote battery,put in dvd wait for the blue screen,then press stop 2x then enter 1264 then,if you have a up,down,l/r control on the deck press down 1x then press play,you dont even have to use the ground wire then go to the rest, when you can see the menu,i dont know if it will work but u can give it a try
Jun 18, 2009 | Phase Linear UDV9010 Car DVD Player
How can i watch dvd while i drive?
its very sample. you will insert a DVD and everything will be start and going automaticly.
May 29, 2009 | Phase Linear UDV9010 Car DVD Player
Wiring uv7i
you can use the deck without a remote, the only thing is you cant go into the system without the codes. there is a sequence code you must enter to disable it. there are a couple of videos on youtube but none for the uv7i. trust me, i 've been there on and off since the summertime. i am not sure if the sequence works due to me not hooking it up to external monitors but you can disable the blue screen with a on/off switch...only problem is, you'll have to do it everytime you turn your car on. here's what you do....
buy a on/off switch(radio shack $3)
hook the pink wire to one part of the switch-the other to the negative ground
put a dvd in(from what i hear, it must be store brought), wait unntil the blue screen comes up
turn the switch off...wait two seconds/turn on...wait two seconds/turn off...wait two seconds and turn back on. the blue screen is gone and video is on. ifyou still need the diagram, i'll scan mine for you.
Nov 09, 2008 | Phase Linear UDV9010 Car DVD Player
Phase linear UV7I
I Need Phase Linear uv7i Owners Man. Also Vol. Control Goes Up As You Turn It Down. Repairs??? C/D Dvd Not Working! Help!
May 27, 2008 | Car Audio & Video
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
102 people viewed this question
 Grubhead
Grubhead
