Question about Xact Communication Xact XG2400 2.4 Ghz Cordless Phone System with Color Caller ID and Digital Answering System
How do you change outgoing message? - Xact Communication Xact XG2400 2.4 Ghz Cordless Phone System with Color Caller ID and Digital Answering System
How do I change my outgoing message
I need the phone Model # ? You can go online and google the phone and how to get through the menu options.
Nov 05, 2014 | Uniden Cordless Phone
Change outgoing message
Usually, the voicemail message is stored in the voicemail system, which is handset-independent. Call in to your voicemail (usually hold down the 1 key or look for the key with the envelope and hold it down - it will dial your voicemail account) and follow the prompts to set up your mailbox, and "change your greeting."
Dec 11, 2013 | Motorola Cell Phones
Cannot change outgoing message on Lucent Partner 18D phone system
For an extension of the Main Automated Attendant greeting when callers call in.
Which voicemail do you have? You indicated the phone model, but not the voicemail model.
Jun 16, 2009 | Avaya Lucent Partner 616 Phone
WE NEED TO CHANGE OUTGOING MESSAGE ON WORK PHONE DTU-16 NEC
voice mail procedure manual can be downloaded at www.natgtelecom.com/elitemailug.pdf
Jun 15, 2009 | NEC DTU 16-1 Corded Phone
http://uniden.com/pdf/EXAI4248om.pdf
Apr 21, 2009 | Uniden EXA14248 Cordless Telephone
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Xact Communication Xact XG2400 2.4 Ghz Cordless Phone System with Color Caller ID and Digital Answering System Logo
21 people viewed this question
Top Xact Communication Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Xact Communication Lands Phone Expert? Answer questions, earn points and help others
