My 3470 printer has nevererr:0x960F on it and I cannot get it to move. change printer cartridge because it said low ink. thanks.
  • kwbabin Nov 28, 2008
    I am having the same issue. I have a Lexmark x3430, same exact message and it won't even let me power down. I have not changed the toner yet, but I did get a message saying that I needed to change it.
  • 125 Answers
SOURCE: brother mfc-5440cn
The cartridge has no chip to reset. I'm guessing that the problem might be the printer. Have you tried turning off the printer for about 30 seconds? If this didn't work try turning it off and unplugging the usb and power for 30 seconds. This is to reset the printer to recognize a full cartridge. If this doesn't work, did you put the cartridge in the correct position? Is it aligned correctly? Hope this helps.
Posted on Jul 24, 2008
Agent Blue
  • 39 Answers
SOURCE: CHANGING INK CARTRIDGES
For all printers I'm familiar with, it should be on. Some won't even move the carrier (the sliding thing the ink carts go in) over to where you can get to it if you open the cover with the power off. And you'll want to print an alignment page after replacing a cart too or your printout may be blurry (most printers will prompt you to do that after you close the lid).
Posted on Aug 05, 2008
  • 684 Answers
SOURCE: lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Posted on Jan 19, 2009
SOURCE: Canon MP530 print head malfunction
Do you mean the thing that holds 5 catriages? Sometimes, I keep it in the center by hand.Of course, you do not need always hold it. Once it stays, you can move your hands and replace catriages.
Posted on Feb 24, 2009
pineworks
  • 4041 Answers
SOURCE: My printer shows Never ERR: 0x960F What does that
Hi there
I cant see much about this error you have the only thing I see about it is it could be the software driver or your windows need updating just try re installing your driver you may need to unsiall the driver first. All the best
Posted on Feb 13, 2010
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
I have changed a black ink cartridge, bur my yellow and blue ink cartridges are too low to charge/clean so the black ink is not coming through. A little message comes up telling me that the blue and yellow...
Hi Good day!!! try this trick ^_^ open the cover of your printer to see the print head, now turn off your printer you will see your print head is moving when it moves to the center pull out the power cord of your printer ( this trick is about good timing) if success the print head is now in the center now remove the ink cartridge (note don't installed the new cartridge yet) now turn back on you printer without the cartridges, your printer will recognize that the cartridges are missing, ^_^ and finally your printer will find the your inks after that insert it according to its location.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Please help me find the spot to re place the ink cartige to an x 3470 printer
Perhaps the Lexmark X3400 Series User's Guide will give you a better picture. You can download it using this link: http://bit.ly/cSUqq8. Scroll to page 52 for the instructions on how to change the print cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thank you for choosing Lexmark.
Oct 15, 2010 | Lexmark X3470 All-In-One InkJet Printer
Hi there
Feb 13, 2010 | Dell 946 All-In-One InkJet Printer
How do you replace ink in EPSON TX110? Paul
The procedure is shown on the panel you can see if you open the cartridge compartment of your TX110. However, it can take some effort to decipher the icons. It is known to work if the ink low light is on, untested otherwise.
  1. Turn on the printer.
  2. Press and hold the STOP button until the cartridge tray moves out of its bay. It will stop at the ink low notch pointing to the first cartridge out.
  3. Press STOP again. The cartridge tray will move to show you the next cartridge low on ink.
  4. Repeat until you know all cartridges out. After the last cartridge pointed to, the tray will move again and stop in the area where all cartridges can be accessed by hand.
That's it folks!
Nov 12, 2009 | Epson Stylus NX400 InkJet Printer
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink cartridge
If you have a 3470, you need a #1 cartridge. If you have a 3480, you need a #2 cartridge. If it is a 3400 series, there is only one cartridge. It lets you print both in color and in black.
Jan 22, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark 3470, new ink dosn't work.
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
471 people viewed this question
jasbo
jasbo
