Question about Onkyo Audio Players & Recorders
Onkyo HT-R667 7.1 Receiver with Video Connection Problem
I have an Onkyo HT-R667 7.1 receiver that is plagued with a video connection problem that has recently gotten worse. I have all three current-gen gaming consoles (Xbox 360, Wii, and PS3) that are connected to my Onkyo receiver, which is connected to my HDTV via HDMI cable. The Xbox and PS3 are connected to the receiver via HDMI as well, and the Wii via component cables.
The issue I experience is when I turn everything on (i.e. the tv, receiver, and PS3), the receiver doesn't connect the video (or sometimes video and audio) until I toggle the power on the receiver a few times, switch inputs, or just wait approx. 5 minutes for it to connect. Any idea as to why this is happening? If I wait for it to connect, the black screen slowly starts to get fuzzy and the picture will sort of fade in and out until its completely visible. I have reconnected all of my peripherals and it hasn't fixed the problem, although sometimes it works just fine and other times it can be a nightmare.
ANY help is appreciated.
CremeStout
  • 115 Answers
SOURCE: Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Posted on Dec 03, 2007
SOURCE: Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Posted on Jan 27, 2008
The Machine
  • 788 Answers
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Posted on Jul 09, 2008
dunnbiker
  • 8546 Answers
SOURCE: Denon AVR 2106 clicking noise
I like when a user is observant and curious. That will help immensely in resolving this problem.
What source(s) are always involved with the problem?
You imply it is observable with output video to the TV - "only when there is movement on my tv screen and it stops in still screen". That sounds like a digital pathway problem of some sort as any data errors would eventually escalate to something audible or visible to you once the hardware and correction algorhythms are exhausted. The clicking inside the receiver could be its efforts to resynchronize with a bad data stream. Hence, I'd like you to isolate the ins and outs that fail all the time and find the probable single source of the problem.
Try this: put a digital source on and select/deselect it for listening or viewing. Does it make the click in that brief time it's 'thinking' before you hear the source? That would be the 'normal' sound. My Pioneer does it once per source switch. Repeated clicking would mean it's struggling.
I'm betting you have an optical or hdmi cable that's flaky or not in tight and straight. Or, if only one extternal source is involved we follow that back.
Posted on Apr 29, 2009
satavlad
  • 405 Answers
SOURCE: Onkyo SR606 video upconversion problem.
It is a common problem for this model. One or a few capacitors on HDMI board have to be replaced. Sins they are surface mount, I would not recommend you to attempt replacing them. Contact Onkyo to arrange service.
Posted on Nov 29, 2009
Can I connect a tv antenna to an onkyo HT R-550 receiver? I see only fm and am. Thanks.
Hi Mark, You can't connect a TV antenna to our receivers they do not have TV tuners. Thank you, Onkyo USA
Oct 21, 2016 | Onkyo Audio Players & Recorders
Only plays through one front speaker when in video mode.i've tried v-1 v-2 and v-3. i'm using optical for audio
Hi Richard, please make sure that the source has been assigned to the optical connection via the setup menu or you can select the source and then press the digital input button until the display shows the optical connection where the physical connection was made on the back of the Onkyo, Thanks, JT
Apr 01, 2015 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
No tv picture when satellite receiver connected to HT-RC370
make sure you have selected all the right av's from the satellite to the receiver and from there to the tv. dont forget to select the input you connected the satellite too
Apr 15, 2014 | Onkyo receiver HT-RC370 User Manual
I dont know how to connect it to my tv!?!?!?!
Look in the manual.
http://www.retrevo.com/support/Onkyo-HT-R500-Receivers-manual/id/365bh147/t/2/
The only vital connection is a simple composite cable or whatever your unidentified TV requires. The TV has a manual, too, somewhere.
I personally would not bother routing any video from external sources through the receiver as no signal will benefit from the extra cables and connections.
Aug 13, 2011 | Onkyo HTR500 Receiver
I have purchase an onkyo HT-RC230 receiver. I want to connect a Directv R16-500 DVR & RCA L32W22 TV. Directv satelite service is currently connected to the DVR and DVR is connected composit S ports of ...
This is a rather uncomplicated satellite receiver, and basically only has a left/right audio out.
You can hook these into any of the stereo type inputs on the HT-RC230.
This receiver is also the "wal-mart" brand of Onkyo (not their best stuff) - so I suggest you take the L/R audio out on the DVR and put it into ANY available (cd/tape/dvd) stereo input on the receiver.
You aren't going to get better sound out of any specific input.
Feb 21, 2011 | Onkyo Audio Players & Recorders
No audio from my PS3 through the Onkyo 5100 7.1
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
I haven't researched to actual manuals for your equipment, but I'm guessing that the optical may be disabled when the HDMI is used. You could try using the component video outputs to the TV and then the optical to the Onkyo.
Jan 02, 2008 | Onkyo HTR500 Receiver
Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Jan 01, 2008 | Onkyo TX-SR605 Receiver
549 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
