Question about Dryers
Can you wire in a motor from a different kind of Kenmore dryer? The specs are the same the only difference is one has a wiring harness and one of the colors doesn't matchup. I have been looking for a schematic with no luck.
    Genius:
  • 1,028 Answers
If shaft length is same should work look for numbers on wire and on motor block might try matching by number rather than color
Posted on Apr 24, 2008
New motor wiring connection to old wiring harness
without any info,,i;e,,make,model,year,
problem,,WHAT KIND OF ANSWER
DO YOU EXPECT???
Apr 17, 2015 | Cars & Trucks
What is the difference between 96 dodge ram 1500 harness than a 2001 dodge ram harness
you are going to have a wiring harness for both vehicles because they are going to be totally different the make and model different and all the different types of controls and upgrade one has, the computer wiring diagram or layout, the older vehicle may have less wiring than the newer one, all the new electronic devices installed on the newer car compared to the older vehicle. lights setup, if has power door locks, power windows, power trunk, powered whatever,
anti-braking, the vehicles computer system will all be different setup, codes for the devices in the car. it mite have the same motor but that all it will be just the motor.
good luck
rod
Mar 26, 2015 | Dodge Ram Cars & Trucks
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How do I connect wiring on Kohler CV16S motor to craftsman mower that had a B&S YBSXS.7242VFmotor?
You need to know which ones are the kill wire, charge wire and starting wire for both side of the harness and make you own connector.
Dec 06, 2017 | Garden
Hi Ginko. I have a Kenmore dryer model 11086810100 that has some wires removed from inside. The only HOT I can find is the red wire. I have 2 wires that have femals push-on crimped terminals, but I have no...
Hi Robert.
Thanks for the pics. I operate in UK and color codes here are different.
From what I can see the wiring in your picture does not match the US standard either.
The thermal fuse for example should have two blue terminals, not red and blue. The thermal fuse wires goes on one side to start, and on the other to the drive motor through the broken belt switch (if present).
The wiring at the blower must be revised and done again.
Here a service manual covering Kenmore 70 series dryers.
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
There is a wiring diagram at page 25.
Here a picture showing correct wiring: http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
See also the pictures in this blog:
http://www.satfix.net/showthread.php?931-How-Dryers-work.-Whirlpool-Inglis-Kitchen-Aid-Kenmore-Admiral-Roper
About the red and yellow cable, the only red yellow wire in the diagram operates the switch for the guard function. The wire becomes hot and powers the motor when the guard switch is closed.
Parts (including wiring harness and terminals) are available here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086810100/0582/0151200?pathTaken=&prst=0&shdMod=11086810100
Jan 02, 2012 | Kenmore Dryers
I have an F40 code on my Kenmore Elite Dryer, model # 110.67092600
Fault code F40 is a communication error between the machine control and the motor control. Disconnect power then remove three screws from the rear of the console assembly and pull console towards the front of the dryer to hinge open and remove console. You'll see three electronic assemblies; the machine control electronics, the motor control electronics, and the user interface electronics.
Visually check the communication harness, the three-wire harness that connects between the machine control electronics and the motor control electronics. Make sure it is fully inserted into both electronic controls and the terminal connections are clean. Reseating the connections several times will help clean off dirt and corrosion build up.
Do the same with the the wire harnesses connected to the motor control electronic assembly. Make sure they are clean and fully inserted into the control. It is a good idea to do the same thing with all other wire harnesses in all of the electronic assemblies.
Aug 09, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
F11 SHOWS ON THE PANEL.
HI. This is a Serial communication error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.(usually the wiring harness will need to be replaced in this case, but a faulty Motor Control Board is not uncommon)
Aug 01, 2009 | Kenmore HE5
Sears kenmore dryer wont run (Electric)
Sounds like the motor relay and/or the even heat board. Remove endcaps from console and remove 2 screws in corner. Pull console torwards you and up and it will flip up. The board is on the left and there are 2 relays on the right. The only difference is one has big red wires and the other has smaller blue ones. Blue wires are motor relay. Possibility of door switch also broken off.
Mar 08, 2009 | Kenmore 63942 Dryer
Kenmore HE3 stops in middle of cycle, flashes F-11.
F/11 Serial Communication Error
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check MCU
  • Check CCU
  • Check Motor
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
35 people viewed this question
Top Dryers Experts
