Question about Bertini Shuttle TS Sport Standard Stroller
I need 4 new wheels and a all black hood can
I need 4 new wheels and a all black hood with the moon and stars pattern inside can anybody help .
    Problem Solver:
  • 5 Answers
I posted 4 wheels on ebay today 7th nov and I have a black hood with silver strps if its any good . phone no 01904637432.Fisher.
Posted on Nov 07, 2010
What is the torque setting for the front wheel barring on a 1998 VW Sharan 1.9 TDI?
90 lbs. and torque them in a "star" pattern, otherwise the wheel will not be mounted correctly and will vibrate at high speeds. By star pattern... I mean not circular, hence torque each opposite stud in sequence and it will work perfectly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/eric_5179db65226039e7
Jul 20, 2014 | Vehicle Parts & Accessories
What are some nouns describing the sun and some nouns for the moon?
Nouns that describe the sun include day-star, solar disk, solar orb, eye of heaven, great luminary, light of the day, lamp of the day, source of light and giver of light.
  • Nouns do not describe; adjectives are the describing words for nouns.
  • The word moon is a noun, some adjectives that describe the moon are: bright, cool, round,full, half, new, crescent
Feb 28, 2014 | Hasbro Toys
Hi ive got a galaxsee tasco telescope but im having trouble seeing anything at night, i've took all the caps off lined up on a star but its just pitch black can you help thanks.
1. During the day, point the scope towards an object and align the finder scope to the telescope.
2. First object at night should be the moon. it will verify your finderscope alignment and you should have a clear view of the moon.
3. Use your lowest power eyepiece (largest number in mm) and point the finderscope to a star. The star should be in the center of the eyepiece.. If not, adjust the finder until it and the scope are centered.
4. You can use your higher power lens on the star nd it should still be in the FOV (field of view)
5. Scope may need to be aligned (collimated). Instructions on this should be included with the scope
Mar 10, 2011 | Tasco Galaxsee 46114375 (375 x 114mm)...
Hi, a few days back I purchased Nexstar 4SE. I set it up exactly how it says in the manual still I cannot see any magnifying views from the eye piece. While aligning the telescope I can find the moon from...
Stars will always appear as points. It is not possible to magnify them enough to see them as disks because they are all extremely far away. A telescope will however show you stars and other objects that are too dim to see with the naked eye.
You will be able to see the planets as disks, and even features on the planets, such as the bands on Jupiter, the rings of Saturn and the phases of Venus, and also moons around some planets. There are other objects that will show more detail when magnified, such as nebula. You will be able to see a lot of craters and other detail on the Moon.
Your problem is simply that you are not pointing the telescope at these objects. This seems to be one of those telescopes that "automatically" finds objects, but these so called "go to" scopes only do this when they are set up properly. I can't say what step(s) you have missed, but clearly even if the scope thinks it is pointed at the moon, if you can't see the moon, it is NOT pointed there. The Moon will fill the field of view even with the least powerful eyepiece. If you are seeing stars as points, then the eyepiece is focussed and working properly.
Jan 13, 2011 | Celestron NexStar 4 SE Telescope
I have quite an old tasco telescope. we can see the target star/planet with the finder, but when we switch to look thru the magnification, we see only black. the lens cover is off. dod you ahve any...
You have NOT lined up the finder scope with the main tube. Point the scope at the moon or a bright star and get the moon or the star into the main tube's eyepiece.
Without moving the scope adjust the screws on the sides of the finder scope and center the crosshairs on the target. Now you can use the finder to line up the main tube.
Sep 28, 2010 | Tasco Optics
Need to change front brakes. Grind metal to metal sound. What tools needed and how to do it?
Hello, you will need a a standard socket set, C-clamp brake fluid, jack and jack stand. First open your hood take off the brake fluid cover. Loosen the lug nuts to where can be removed by hand. Raise the car high enough to get the wheel off and support it with the jack stand. Remove the lug nuts and wheel. Lower screw on the caliper, rotate the caliper upward. Remove the old pads, use one of the old pads to push the piston back in th caliper. Align the old pad to cover the piston evenly, using the C-clamp position it to where it contacts the old pad in the center and slowly turn to push the caliper in ward. Once the pad contacts the caliper give another half turn. Install the new pads, positioni the caliper back to the normal position over the new pads, reinstall the lower screw on the caliper. Put the wheel on install the lug nuts in a star pattern, only hand tighten. Remove the jack stand lower the car tighten the lug nuts in a star pattern. Check the brake fluid add some if needed, replace the brake fluid cap and pump the brakes until the the brakes are firm, start the car pump the brakes a couple extra times and check the fluid add if needed. The fun part the test drive, allow your self more than normal stop distance.
Jan 26, 2010 | 1999 Pontiac Grand Am GT
Is samsung star and s 5233 same
Yes Its The same thing.
Samsung Star S5233.
Launching New Here
And Good news available for INDIAN MARKET.
Check Here
And before purchasing have a review On YouTube Here
If i was helpful, kindly do Rate!
Jul 18, 2009 | Samsung SGH-L700 Cell Phone
The belt came off of my 2003 cadillac dts and i cant find the pattern to fix it
should have pic of pattern on hood or rad support if not all groved wheels inside of belt and all smooth wheels outside belt usually when almost done u should only use tensionor to finish putting on belt at the alternator worst comes to worst go to used car dealer n fake looking at car like yours and get pattern
Dec 03, 2008 | Cadillac DTS Cars & Trucks
Broken light switch on a Nutone
The Black 120vac Line In wire goes into "L". The Black wire goes into "2". The Red Wire goes into "3". When you install the switch, the Red and Black wires will be on top of the switch.
Jul 17, 2008 | Broan-NuTone Intermediate Whispaire ...
Bertini Shuttle TS Sport Standard Stroller Logo
98 people viewed this question
Top Bertini Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Bertini Baby Gear Expert? Answer questions, earn points and help others
