Question about Refrigerators
My fridge is a Whirlpool side by side about 25 years old, model # ED19TKXMNR0. Got up one morning, opened the door and the interior was soaked with condensation. I could hear it running but not as loud as usual, like it was idleing. Checked the freezer temp, 40 degrees. Looked like it was not running for 3 or 4 hours. I panicked ! Twisted the temp control in the freezer back and forth a few times, nothing. About 10 minutes went by and it started to run and cooled down to normal. This was last Sunday morning, has been OK since. What's going on, is it ready to die or can I fix this. This seems like it could happen again and maybe not come on.
    Genius:
  • 1,478 Answers
From what you posted, there is nothing wrong with your refrigerator, your refrigerator was only going through defrost, that was the reason for the interior that was was soaked with condensation, while the refrigerator was idle, it was on defrost, this is a normal process on refrigerator when ice are build up at the back of the refrigerator, to under defrost, so relax, whenever you see your refrigerator undergoing defrost.
Your refrigerator is still in good shape for now, so don't bother yourself on this.
Take care.
Posted on Jul 27, 2010
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Whirlpool Refrigerators
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHIRLPOOL SIDE BY SIDE fridge GD25DFXFW 10 YRS
Get your refrigerator repainted before it is too late. It isn't that costly. Cracks may be due to rusting. Ask those mechanics about it when you give it for painting.
Apr 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool model HAXNQ : lights out on fridge side only
Hummm... I would suspect your DOOR SWITCH on the fridge side... $11.321 shipped... eBay!
Anthony
Whirlpool 1118894 Door Switch
Dec 02, 2017 | Whirlpool GS5SHAXN Side by Side...
Refrigerator not cooling adequately
The answer to the temperature range is NO. It should be 36-40. Could the thermostat be faulty? Are the doors sealing properly? Is the interior light remaining on, when the door/s are closed? Open the door and depress the door switch. See if the light goes out? Being 25 years old, technology has come a long way. Purchasing a new unit wouldn't be a bad idea.
Jul 13, 2009 | Refrigerators
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
DOOR GROMMETS ON BOTTOM OF REFRIGERATOR DOOR IS BROKEN
get it from the service agent spares
take the old one as a sample as the bush could be generic and fits most doors on many fridge makes and go to all of the manufacturer service agents for a spare one
Sep 24, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool WRN38RWG6 fridge freezer. Fridge won't cool
...try taking the fridge to Thredbo or some other location that gets subzero temperatures and then leaving the door open 'til the interior cools down. Canberra this time of year could work. You could also try just filling it with some frozen water. Most service stations have it in plentiful supply. Best solution for a non-hottness deficiency.
Dec 07, 2008 | Whirlpool Refrigerators
Interior walls cracking...
i don;t think there would be a health issue involve.
the old fiber glass has been replaced with polyurethane foam now a days to replace the more dangerous fiber glass insulation.
if you can replace the plastic part that cracked open, that would much better.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
