Question about HP Mini 1000 Netbook
The display color is off - HP Mini 1000 Netbook
    Problem Solver:
  • 18 Answers
Check your display drivers. Update them if needed. If the problem persist check the connections inside the laptop (sometimes they can become loose especially if the netbook has been dropped) Worst case scenario you may have to replace the screen.
Posted on Jul 28, 2010
My screen is now displayed upside down, how do I fix, i pressed something and it turned, help , it is a e machines laptop
My Laptop HP Pavillion TX2500 incorrect color display during bios and startup but when the laptop is hot it displays the correct colors.But if cold displays incorrect colors. what can I do?
Jul 18, 2011 | Computers & Internet
Display colors too light to see
Go to control panel---->Display------>check if the display is nVedia or Intel. Accordingly follow the steps and use the best, with color depth enhancement set the display for your type of monitor to achieve the and also check if Icons have 100% opacity and not translucent ....sodeep
Oct 31, 2009 | Microsoft Windows Vista Ultimate Edition
Can we stop it from changing color
Hello bd1340,
The JVC KD-SC500 ships with the color selection set to "ALL DEMO" which alternates the colors approximately every 6 seconds.
To cancel the "ALL DEMO" and select a single color display, go into PSM mode by pressing and holding the SEL Button until the display changes. Use the left/right rocker until COLOR is displayed. Turn the VOLUME knob to select the color you want: Blue, Ocean, Purple, Pink, Rose, or Red. Press the SEL button again to exit PSM mode.
Hope this helps.
Aug 22, 2009 | JVC KD-SC500 CD Player
Discoloration - No display of RED Color
unplug for 10 min to reset then plug back in go to menu and configure the color
Jun 06, 2009 | Microsoft Windows XP Media Center Edition...
Dull colors on 8550 phaser printer
Looks like you don't use the Magenta ink that much, on this machine because it is so hot all the time after a while the magenta can get a strange brown colour and the cyan can get like a aqua marine colour. All you can do is purge the magenta by printing magenta sample pages or just wait until it goes away.
Also you could try the following Tek Colour correction (but It probably won't work). See below
TekColor
Description
Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
  1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select the required color correction.
Feb 20, 2009 | Xerox Phaser 8550DP Printer
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Changing faceplate colors.
only the display changes colors.... your deck is doing what it was designed to do!
Mar 18, 2008 | Sony XPlod CD Player w/MP3 Playback...
Color printing problem~only green, yellow, blue
The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use.
TekColor
Description
Apple Macintosh OS 9.x:
  2. Click on [General], and then select [TekColor] from the pull-down menu.
  3. Select the required color correction.
Apple Macintosh OS X, (version 10.2 and higher):
  2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu.
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
DISPLAY
Your phone's screen connectors might have a problem and need to be replaced by new ones or they need to be placed correctly. this might have happened due to a fall of your phone on the ground.
Oct 07, 2007 | Nokia 6670 Handheld
Incorrect Color Display
i think it has magnet on the other side of your monitor try to locate the magnet and removed it. magnet can change the color and display of monitor. or contact an expert technician of monitor.
Nov 05, 2006 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
HP Mini 1000 Netbook Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
