Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Tv mitsubishi ws55311
My tv turn on and turn off alone
    Genius:
  • 1,694 Answers
Remove front lower speaker grill,then remove access panel =
unplug white connector ( goes to front controls )......Does the set
work now with remote ?...= bad tactil switch on front panel......T.
Posted on Apr 24, 2008
  • Robert Hinson Feb 13, 2012
    I get the 2 - 4 code when I do that on my tv that will only stay on for 3 seconds. Mitsubishi WS-55311.
    Oops. Wrong place for me to post that. Ment on another tech.
Its a mitsubishi ws-55413 projection tv. the tv stopped receiving the remote funtions.
Have the remote tested alone--all shops can do this and if it tests good suspect the remote receiver in the set (usually is dead center behind the screen in the middle above the lens.
May 19, 2012 | Mitsubishi WS-55413 55" Rear Projection...
V-chip reset do not know the 4 digit passcode and i need to remove the v-chip lock so i can watch TV how can i do this?
If model number is correct WS55311 this set has a hidden menu (actually 3 of them) and one is the "Option" menu where you can do a hard reset of the set; it buts everything back to factory default.
It is done with a 4 digit code (I know depending on what model number is) and the original Mitsubishi remote has to be used for this.
Confirm actual model number and I will give that code to you.
sd tech
Nov 08, 2011 | Mitsubishi WS-55311 55" Rear Projection...
What is the wattage for the WS-65411?
POWER
AC 120V 60Hz
240W
Only WS73411 takes 275W otherwise, all other model with this series like
WS48311
WS55311
WS65311
WS55411
WS65411
WS73411 take 240W as yours.
Hope you are talking about main wattage. Audio wattage is exceptional.
best of luck
Jan 27, 2010 | Mitsubishi WS-65411 65" Rear Projection...
Need Horiz button help on Mitsubishi 45" TV...easy fix?
No,require new main video backlight board,and vertical/horizontal stablelizer board also.Both boards alone cost u about $500 bucks not uncluding labors yet.
Oct 20, 2009 | Mitsubishi VS-4544 45" TV
My Mitsubishi tv has a timer light that is green and has been blinking and have not yet turn on, if you can help please send me a pic of the dm board and the capacity module that i have to solder
the digital module is bad, it costs about $800 for the part alone and sometimes other boards go bad along with it, this is the absolute hardest tv to service, no way you will be able to tear this thing down to even get to the digital module. you need a qualified tv repairman and alot of money to fix this.
Sep 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
I cannot power up my mitsubishi 55711
This sounds like the flyback unit on the main board has went out(this contro;s the power to the differnt areas of the TV (a flyback costs around 70.00 and you can order one at www.sears,com yhe parts dept...Have make and model ready!
Dec 13, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi hdtv projection model WS55311
I have an owners manual. I could send a copy for $10. Deborah deboraha-a@comcast.net
Jan 13, 2008 | Televison & Video
How do i get my tv at 1080i
First of all your system, tv, must be able to perform your request, Secondly, your service must be able to provide the 1080i or 1080p, not all service's provide the service with the equipment they provided you (your box). Check with your provider.
Nov 17, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
