Question about Panasonic Workio DP-1820E Copier
DP-1820E - Contact Your Dealer - Printer Error E02-01
HELP! My copier stopped feeding paper, started making a strange noise and the display now reads:
Anyone have any idea about that error code. I cannot find anything in Google.
Thanks!
  • cyndeew Oct 21, 2008
    we also get an error code 02-01, loud clicking noise only in tray 1 not tray 2..
    any ideas on how to go about and fix this?
    Sergeant:
  • 284 Answers
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Posted on Sep 30, 2008
    Problem Solver:
  • 9 Answers
Uhh tanks
Posted on Nov 24, 2009
Pull paper tray out and see if paper is lodged behind the tray.
Posted on Dec 01, 2008
  • Mill Bullard Jun 03, 2014
    usually it's the tray not all the way in or paper stuck behind cassette
    if not the lift arm is bent or the screw has broken off.
Regarding E02-01, There are some problem in tray lift-up motor. check the same.
Posted on May 19, 2008
Panasonic dp-1820e paper not detected
Listen to see if the lift motor is working properly...if it doesn't lift the paper then the machine will think there is no paper installed in the paper tray. The lift motor will need to be replaced if this is the issue.
Aug 13, 2014 | Panasonic Workio DP-1820E Copier
Lazer priter not picking up paper ever thought tray is full
open the paper tray and clean the rubber feed tire.
use a baby wipe or windex.
Mar 28, 2011 | Panasonic WORKiO DP-1820E All-In-One Laser...
Panasonic DP1820E check printer E02-02 red spanner
yep!
e2-02 means there is a machine error of lifting motor assembly for tray #2.
For sure this time you can't use your tray #2.
you may check it sometimes there's just a paper clogged at the rear of the paper tray. just remove your 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Mar 14, 2010 | Panasonic Workio DP-1820E Copier
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
DP-1820E shutdown the Print Spooler's Windows Service
Had same problem. Downloaded Standard GDI printer driver from http://www.bayshoreoffice.com/drivers/ dated April 11 2007 and overwrote old driver with the updated one (ver4.2 I think) and printing to DP-1829E was restored. Strangely PCL printing won't work at all!
May 16, 2008 | Panasonic Workio DP-1820E Copier
Panasonic Workio DP-1820P
Printer Error E02-01 appears when paper tray number 1 lift-up motor is unable to lift papers, Check whether the gear box of the motor is broken , normally replace the whole unit
Apr 30, 2008 | Panasonic Workio DP-1820E Copier
Dp-1820e rebooting not starting
you may try this:
unplug the network, usb, and fax connection
remove all papers
turn on the machine
press print key
press stop
press 1 for yes to cancel the job (if theres a job queue)
Mar 31, 2008 | Panasonic Workio DP-150PA Copier
Panasonic Workio DP-1820E Copier Logo
2,626 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
