Question about Polycom SoundPoint IP 501 IP Phone
Need Polycom 501 setup steps for sipgate + vierizon fios & actiontec router + nat. can't find solution anywhere.
2 Suggested Answers
SOURCE: just installing polycom 501 phones with nextiva
Ohh this mean, you did not register this extension on your phone system. Create this extension on your phone system. Be sure that password given on Phonesystem is also configured on phone too.
Posted on Nov 14, 2008
Actiontec GT724WG NAT from strict to open
Factory reset the router, 98% of time solves problem with Xbox, you shouldnt have to configure and thing after the factory reset, just reconnect via ethernet or wifi. you hold down the reset button on the back of the router for 12+ seconds while the router is turned on. wait 1-2 minutes for reboot
Apr 13, 2014 | Actiontec Computers & Internet
I want to open my NAT my i have the GT701WG model tell me what ports to open
Log into your router. Under "WAN setup" or similar you should see "NAT filtering" or similar. Check the box next to "open". Be advised that opening NAT exposes your network to the Internet. Better to find out which specific port is needed for your application and stipulate that under "port triggering" or port forwarding.
Jan 28, 2011 | Actiontec (GT701WG) Wireless Router
I have an actiontec router and cant set my nat type to open. If i turn off nat i cant get on xbox live. It says in the actiontec website for my router that i have to do something with port forwarding to...
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is enabled
Aug 09, 2010 | Actiontec (GT701WG) Wireless Router
Need to change my nat setting from strict to open can't find anywhere on belkin wireless router settings
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
Jun 23, 2010 | Belkin Wireless-N Wireless Router with...
Polycom 501 phone keeps trying to reboot itself. We rebooted manually a few times and get the same error message: 'Could not find boot server current configuation" Any ideas?
try to turn off the Polycom device. When you turn it back on, press Setup. from the options, select server then click edit. Then select the item Trivial FTP (that setup depends on your ISP), and type the IP address assigned to your network (example 192.168.90.90) then hit OK. click exit several times then press Save & reboot. If it did not work, let us know...
Jun 19, 2010 | Polycom SoundPoint IP 320 SIP IP Phone
I got nat type 2 on my ps3 internet test,but wen i go on the screen to invite my mate its says nat type moderate,on my mates it says nat type open,y is this & is this the problem we have inviting each...
PS3 And XBOX :: BELKIN
Step 15:Enable UPnP
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Feb 12, 2010 | Sony Playstation 3 (PS3) Console
Wireless capability not turned on
Turn off all PC's that are attached to the router. Try unplugging the router for at least two minutes and plugging it back in, then try to turn the wireless back on.
Jan 02, 2010 | Actiontec (GT701WG) Wireless Router
How to open my nat on xbox live with actiontec router
Unfortunately you did not specify which Actiontec Routers.
However I was able to find some very useful information on several Actiontec Routers.
Please go to this page and select your Actiontec Router from the list:
http://portforward.com/routers.htm
Hope it helped.
Nov 13, 2009 | Microsoft Video Game Consoles & Games
Can't get NAT setting to Open for xbox 360. Won't connect to other users with open setting
The NAT is set to the actiontec modem/router so the next troubleshooting is to open the ports of the XBox ports 80, 3074, 53 TCP and 88, 3074, 53 UDP. To allow the XBox on the network using your modem/router.
Jun 27, 2009 | Actiontec (GT704WG) Router
Using Linksys WRT54G as router connected to ActionTec with FIOS
You must keep everything on the same subnet. Only allow the router to be DHCP and keep everything on 192.168.1.x subnet. You are going to have alot of problems talking across subnets
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
Polycom SoundPoint IP 501 IP Phone Logo
358 people viewed this question
Top Polycom Computers & Internet Experts
Darren  Means
Darren Means
Jack Frost
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
