Question about GE JE1540 Microwave Oven
How do i replace the door switch in my ge JE1540ww microwave?
SolutionGuy
  • 331 Answers
SOURCE: GE Microwave JE1640 works only when holding the switch
VK, most likely the switch body has become loose and it's out of adjustment. Unfortunately, to gain access to it, you'll have to remove the MW from the cabinet, set it on a suitable work area and disassemble it. Before doing anything like this, please read the following link carefully and ask yourself if you're up to it... http://www.gallawa.com/microtech/safety.html Remove the trim then remove the screws holding the MW. Pull the MW out and rotate slightly to see where it's plugged in and unplug it. Then pull it all the way out. Remove all the aluminum trim from the MW and all the screws holding the cabinet. To remove the cabinet, stand behind the MW and grasp both sides... pull back and up at the same time. Set aside. NOW!!! DISCHARGE THE CAPACITOR AS PER THE INSTRUCTIONS IN THE LINK ABOVE!!! OK, up by the control panel, you'll see the latch/lock assy. (it has 3 brown switches mounted to it). It's held in place by 2 screws, the lower screw is the one you'll be working on. Adjust this by opening and closing the door and watch the action on how it works and make your adjustments as needed. Now, you'll need to test it before reinstalling. Plug it in, BUT DON'T TOUCH ANY WIRING! Now give it a try. If you need to make another adjustment, DISCHARGE THE CAPACITOR AGAIN BEFORE DOING SO!!! Do this every time you plug and unplug! Continue adjusting 'til you get it. Now, there's a chance that one of those switches is about to go bad and the mounting bracket is fine. In this case, those switches are generic... not GE specific. Remove the wiring from the switches and make notes on their respective locations. Remove the switches from the bracket (starting from the top) and label them 1, 2 and 3. Take these to your local appliance parts store and ask for generic replacements, they are cheap... about 5 bucks each. Then replace them in the same order you removed them. And re-test. This will get you fixed, but please be careful working on Microwave ovens. They are dangerous!
Posted on Sep 27, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: turntable microwave oven (model JE1540WW 002) (serial ZR943877S)
Chances are that it is not actually microwaving, but that can be checked by placing a small cup of water inside.
Overall, though, it's not a good idea to run it if it's not working right.
This problem is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Have a GE Profile Microwave Oven Model JE1540. the
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Posted on Jan 17, 2011
  • 78 Answers
SOURCE: Ge sensor microwave quit working. Replaced the
yes you will have to check the switch
Posted on Jan 20, 2011
tunde007
  • 2382 Answers
SOURCE: On our GE Model JE1640
Hi, in most cases it's not actually cooking, but instead the fan, turtable and light may be on. Yet it does need attention.
What this usually means is that you have a shorted door switch or a bad door switch mount.
It's easy to tell if it's actually cooking, just place a cup of water inside and see if it heats.
If so, that could mean a stuck relay on the control board.
Posted on Feb 06, 2011
What will fit in the cutout for GE microwave model JE1540WW 001 Countertop Microwave
Call GE support and ask them, and be sure to give them the full model number.
800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET Saturday: 8 a.m. - 7 p.m. ET Sunday: Closed For more free DIY help, feel free to contact me via my site. Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 12, 2017 | GE Microwave Ovens
WHERE CAN I FIND A DOOR SWITCH FOR MY GE MICROWAVE WES1384SM2SS
Most microwave ovens use generic "microswitches" for door switching. You will need to open your oven, and find what they look like, and then match them.
I bought replacements here:
Allied Electronics Electronic Components Distributor
but any electronics distributor will have them. Inexpensive, only a few dollars eacy. My ovens actually use 4 switches on the doors, and more than one were bad.
Jun 04, 2015 | GE Microwave Ovens
Why does my ge spacemaker jvm1740dd1cc no longer heats and the turntable does not work?
Bad door switch. Look for burnt terminals on one of the door switches. Replace the switch and cut off the burnt terminals and splice on new ones.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
What can cause a microwave to come on when the door is opened, never seen this before and is very dangerous. it happens with or without time set.
The most likely problem is a faulty door switch, you can buy new switches, but you'd have to follow the diagram here to identify which of the 2 switches you need to replace: See Part # 26
http://www.partselect.com/Schematics/GE/00008593i01.gif
you can find the parts here:
GE WB24X830 Monitor Door Switch PartSelect
GE WB24X829 Secondary Door Switch PartSelect
Jul 14, 2014 | Microwave Ovens
All of a sudden my JE1540WW 003 has died.
check the slo blow fuse and the high voltage capacitor and the high voltage fuse. good luck.
Jul 10, 2009 | GE JE1540 Microwave Oven
Turntable microwave oven (model JE1540WW 002) (serial ZR943877S)
prototech@usa.net
Apr 28, 2008 | Microwave Ovens
GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
167 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
