Question about Hampton Bay HBLG5004 Air Conditioner
It gets really load when the compressor kicks on?
    Problem Solver:
  • 13 Answers
It is normal when the compressor start because the starting current of the compressors 5-8 times of running current
Posted on Jul 28, 2010
I own a Fogel Fridge Model # VR-17-RE-PR Recently
Richard,
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Refrigerators
At 100 deg.it does not shutoff automatically
If your talking about a refrigerator, it never will as its goal is to try and cool, and its trying. It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your frig is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Kitchen Appliances - Others
Comptrssor cuts off wont start
Michael,
If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is getting really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off. I suspect the start/overload relay is bad and causes a high amperage draw which will then cause the over load to kick in. This start/over load relay will normally be right on the compressor and any decent appliance parts store will have a replacement.
Oct 11, 2013 | Samsung Refrigerator Compressor -...
Why does my compressor trip the breaker after filling with air
1 of 2 things #1 the pressure releive valve that lets the pressure of the pump when it kicks off is stuck closed so what is happening is when the compressor kicks back on its under a load and trips braker. #2 your braker is to small for the compressor.
Jan 11, 2012 | Craftsman Air Tools & Compressors
Delfield mini freezer for restaurant is not freezing. Unit has power and cabinet fan runs but comp tries to kick on then you here a click and it immidietly shuts off before it can really ever start. Hi...
Compressor is locked up. You have an outside chance of getting it to come back if you install a hard start capacitor. When a locked compressor tries to start it gets hot really fast and kicks the power off to prevent wires from overheating. You can get a hard start kit from wwgrainger or refrigeration supply company. Many times they won't sell direct to the end user. The hard start kit gives it an extra boost when it tries to start. Most times this won't work. Usually the compressor has to be replaced because it is burned out internally. The hard start kit is less than $20.00, so its worth a shot.
Sep 21, 2010 | Delfield Freezers
My heater stoped working. The houst has been sitting for 2 years and when I used the AC, I had to put a start cap on it for it to work. Now that its winter, the heater will not work. When I turn it on the...
did the start cap fail again didnt say if condenser fan was running if fan not running compressor will over heat and turn off or if coils of condenser are dirty wont let air pass thru
Oct 24, 2009 | Amana Heating & Cooling
Compressor will not kick in
compressor start relay mounted on side of compressor.
Jun 09, 2009 | Whirlpool Refrigerators
My Whirlpool Fridg. Model ED22RF has a problem. The freezer is defrosting and neither side is cold. Sounds like the compressor switch is kicking on for a second and then off but the compressor never really...
yea that sounds like a compressor issue( under 5 year manufactrue warr.) you can try replacing te overload/relay assy mounted to the side of thecompressor , sometimes you get lucky and it works part number 4387767
Mar 26, 2008 | Refrigerators
Heating & Cooling Logo
43 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
