Question about Linksys Wireless-G WRT54G Router
We had a power outage the other day and now i can not connect using the router. The modem works fine but when connected to the router nothing.
    Problem Solver:
  • 5 Answers
Remove the power cable from the modem & the router
then make sure that the modem & router are completely shutdown.
then power on the modem first & then after 15 sec power on the router as well.
Things will work
Posted on Jul 28, 2010
I have a Netgear WNR2000 v4 router. We recently had a power outage.Power came back on in 5 seconds.The cable modem is fine,however the router ONLY shows me a solid green light for power, nothing else.
I would just do the reset, this should allow you to access at factory defaults. (I hold button in for 10 sec).
A solid green (power?) light is good
LAN ports should only light if connected
WiFi port should light if set to active
Mar 02, 2015 | NetGear Computers & Internet
Power outage unable to connect wirelessly e1000
Make sure power is back up. Check both ISP modem and router indicator lights are normal. Test ISP connection with cable. If all is still OK then use the reset button in the back of the router.
FYI - ISP modem might also have a reset. I had to this for TV even though everything said OK.
Aug 29, 2012 | Cisco Linksys E1000 WirelessN Broadband...
My belkin router n3000 stopped working out of the blue , internet connection shows up but no internet
Try recycling the router by unplugging it then after 20 seconds plug it back in. See if you can stay connected. If not, unplug the modem and the router, then plug the modem in and let it cycle up for about a minute or two, then plug the router in and let it cycle up.
If you turn your computer and router off at night, then when you turn them back on, if the router boots up before the modem, it will have connection problems. A power outage in the house causes the same thing if the router cycles up before the modem.
Jun 08, 2012 | Belkin Wireless Surf Router (F7D2301)
My belkin router will not recognize the LAN connection of three PC. It will accept my laptop using the same Ethernet cables. I have recycled the router and reset my network. Still no connection. We had a...
Did you try direct wiring the other pcs to see if they will connect separately? If they won't then check the network settings on each pc that won't connect. Make sure that the gateway address is the same ip address as the router is.
Did it work before the outage, all of them at once? If so go to the Command Prompt (RUN, type in cmd, enter and a small window will pop up), and where the cursor is blinking type in - ipconfig - (some win versions use winipcfg) , hit ENTER. That will tell you what address are set to. It should say 192.168.xxx.xxx.
Type in - ipconfig /release - ENTER. That will reset the addresses which should now all be zeros.
Now type in - ipconfig /renew - (make sure you have the blank space between the g and the /). This should give you the 192.168.xxx.xxx address for IP if your network settings are set correctly under Network Connections- Properties-TCP/IP
Sometimes under outages you need to reset both the modem, the router and the pcs to acquire the new addresses.
Feb 22, 2011 | Belkin Computers & Internet
Router quite working. Wireless does not work nor
Follow this procedure :
  1. Turn off all components on your network - computer, router, modem, printers and any wifi laptops
  2. With the ethernet cable connected only between the modem and the router TURN THE POWER TO THE ROUTER ON and let it boot up.
  3. Turn on the modem and let it boot up to all lights on.
  4. Connect / boot up any and all other components on your network.
Keep this order handy in case of a power outage. Best of successes!
Dec 04, 2009 | Linksys WRT160N Wireless Router
Had a power outage and now router not sending signal. I am not sure these events are related. all lights look good on router and I have internet on wired comp. unpluged modem and router then pluged modem...
Most of the time, routers and modem stops working when it sense a power outage. This is the defense mechanism of these devices to avoid from being damaged.
Turn off the computer, router and modem. Leave them off for 15 minutes. Then turn the modem back on first, wait for 30 seconds.
Then turn on the router, wait for another 30 seconds. After that turn the computer ON.
This would power cycle the router. If same problem occurs, contact the router manufacturer.
Have a great day!
Oct 15, 2009 | NetGear WGR614 Router
XBOX LIVE WORKED ONE DAY AND NOW IT WON'T CONNECT
Try reseting your modem by turning it off and the router off. reinsert power cords. try to go online
xbox live could be out for sometime. this happends..maybe the storm
Jun 20, 2009 | Microsoft Xbox 360 Console
Intermitent DSL/Internet Connnectivity 2701 Router
Hii,
* If you can connect after disconnecting power and reconnecting, it means there is formation of static charge on modem
* Check whether there is any cordless phone or any other satellite devices next to the modem. If so, move the modem 10 feet away.
* If your modem is placed on carpet, please place it on wooden desk
For guest:
Do you see the power is also interrupted while loosing connection? If so try plugging the modem into different socket. Dont waste money for simple problems.
If this doesnt work, please dont rate me down, if it works, please rate me as fixya!!! lol...
Have a nice day!!!
Jun 04, 2008 | 2wire (1000-000057-000) Modem
NOT WORKING AFTER POWER OUTAGE.
are u getting all the lights on the router?if yes then connect the router with modem n if its wireless then turn off all three devices
then turn modem on first n wait till the lights on the modem get settelled,then turn the router back on n the computer,n check whether the computer is picking the wireless or not,if yes try the
internet.
Apr 20, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G WRT54G Router Logo
106 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
