Question about Cosmi Family Tree Maker
Will not install
Just purchased my computer a few weeks ago and i get a message regarding a 64 bit version vs a 16 bit version so program will not load.
    New Friend:
  • 4 Answers
Unfortunately, your computer is only 16 bit and will not load the program you are trying to load which requires a 64bit computer. two solutions. 1. get a larger bit computer or a lower level program which only requires 16bt or below.
Posted on Jan 09, 2014
Error message unsupported 16 bit application
16 bit software is not compatible with 64-bit engines.
The lowest number of software bits, called bit width, a 64b system can sometimes run if lucky, is 32b.
16 bits is the equivalent of 1 byte.
64 bits is therefore 4 bytes wide.
This means that the 64b system reads digitally coded instructions 4 bytes at a time, as one function to perform.
So if it tries to read all 4 bytes of a 16 bit 1 byte program it just sees meaningless garbage.
In fact, the header of the program file will ID it as 16 bits so that the 64 bit system knows not to even try to run it, as random weird instructions could corrupt or damage the computer.
Dec 04, 2017 | Activision Hyperblade for Windows
Dosn't work with windows 7
Broderbund's ClickArt 200,000 Image Pak should install quite easily on a 32-bit version of Windows 7.
64-bit version of Windows 7:
It is not possible to install ClickArt 200,000 Image Pak on a 64-bit version of Windows 7 - because the Setup.exe file is not compatible with any 64-bit Operating System. That is due to the fact that the Setup. exe file contains 16-programming code. 64-bit Operating Systems cannot handle any 16-bit programming code.
Hope this answers your query. Cheers!
May 03, 2011 | Broderbund Clickart 200,000 Image Pack for...
I'm using Windows 7 64 bit & I can't Install "Bitware plus 4.0" in my computer. I see this message after starting Install: Title is: Unsupported 16-bit Application Message is: " The...
any 16 nit or 32 bit is not compatable with 64-bit operating system but yes they do make a 64 bit version of that software make sure your downloading the right version
Apr 01, 2011 | Computer Associates BitWare Plus 4.0 Full...
I had a 32-bit webtricity 2 and other programs that are 32-bit, I have a computer with Windows 7 64-bit and having trouble installing these programs because during compatible with the 64-bit OS is there...
64 bit OS can run 32 bit software but if the software provider has a version for 64 bit it might require you to download this version ad prevent you from installing the 32 bit version.
Kind regards
Mar 06, 2011 | Computers & Internet
I really love this program. I have recently upgraded my computer to Window 7 64 bit and this program runs 16 bit is there any way I can make windows 64 bit compatible with this program.
There is a way of having micrografx draw install and run properly on windows 7 64-bit and also 32bit
The discovery is that most of these programs are not really 16 bit
If you want check out the website at
http://micrografxdraw64bit.site40.net/
If you want more evidence of this let me know
Feb 03, 2011 | Micrografx Small Business Graphics and...
I have a hewlitt packard computer that runs windows vista.When I try to install my cd rom DK DINOSAUR HUNTER it says to contact the software vendor to find out if there is a 64 bit version avalible. It ran...
Unfortunately, you may be out of luck. :( The newer 64-bit operating systems have trouble running the older programs that were designed for 32 or 16-bit platforms. You can try this however: open control panel, click on 'Programs', then click on 'Use an older program with this version of windows', follow the prompts and be sure to choose "I want to use the program in the CD drive". Good luck!
Sep 08, 2010 | Computers & Internet
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
I have Windows 7. Wanted to install Trophy Bass 2 and get this message. Any suggestions? --------------------------- Unsupported 16-Bit Application --------------------------- The program or feature...
unfortunately no, windows 64 bit doesn't support 32 bit or 16 bit applications so you should call the support number or go online to return the unsupported edition for a 64 bit edition (if they have one). Hope this helps.
Jan 30, 2010 | Computers & Internet
O s
The four things that make 64-bit Vista inadvisable for ordinary users are:
1: No compatibility with old 16-bit Windows apps. This means ancient Windows 3.x software, which most people don't run any more, but 16-bit code can still pop up in the darndest places. Like, for instance, in the installer programs for other apps.
2: No automatic registry and file redirection, which is what 32-bit Vista uses to allow existing software to work with Vista's better user account security, even if the software wants to do admin-rights stuff to the registry and Program Files directory. Many apps still break in 32-bit Vista, but many more break in the 64-bit version.
3: No compatibility with existing 32-bit drivers. Everything on your computer will need a new driver. 64-bit WinXP is the same, and there aren't many 64-bit computers on which Vista won't at least install, but 64-bit Windows also has...
4: No support for unsigned drivers.
Jan 28, 2008 | Computers & Internet
Cosmi Family Tree Maker Logo
Top Cosmi Computers & Internet Experts
Alun Cox
raysaw
Are you a Cosmi Computer and Internet Expert? Answer questions, earn points and help others
