Question about Amana DLE330RAW Electric Dryer
Amana dryer loud noise
My dryer is making a loud screeching noise when on
  • 2 more comments
  • Anonymous Nov 11, 2008
    I'm having the same problem. Extremely loud (almost can't be in the same room with it) when it is turned on, but everything else seems to be functioning normally.
    Any recommendation on WD-40 versus other lubricants?
  • Anonymous Feb 01, 2009
    had the same problem three times, the support rollers locks up on the shaft.
    heat from the gas burner flows directly onto the roller, bad design. Bets to buy a replacement kit, pretty cheap, and takes me about 30 minutes to change out. I installed a diverter for the heat, and have made it 6 months now without a replacement.
  • Anonymous Mar 15, 2014
    maytag bravos
  • Anonymous Mar 21, 2014
    My dryer is screeching loud
    President:
  • Amana Master
  • 2,651 Answers
Remove the lowe acesss panel( 2 5/16 screws) wiht the panel removed and a flashlight in hand, turn on the dryer and watch it tumble. you should be able to pinpoint where its coming from. its either the rear roller supports, the front drum glide assy's, or the tension pulley in ehich the belt its wrapped arund(develops a rut in which the belt has cut into it causing horrible screeeching noise, heck to replace all three of the components is problavle ony 50 bucks or so
Posted on Apr 24, 2008
With the panel removed, If there is a collection of dust around everything. Take a shop vac and clean the areas you can reach. then W D40 the belts and pulley and wait a minute and turn it on and see if that doesn't work
Posted on Oct 02, 2008
My Amana distinction started making a loud sound like maybe the belt and I have to take cloths out of it. Now it stopped altogether. Is it the belt or drum?
Amana Dryer Makes Noise - Model DLE330RAW - Repair ...
www.repairclinic.com/...-/Amana-Dryer-makes-noise-DLE330RAW
When the drum rollers are worn out, they can cause the dryer to make a loud rumblingnoise. To determine if the rollers are worn out, inspect the rollers. If one or ...
Nov 26, 2015 | Amana Dryers
The problem I am having with my Amana model NED7800AYW makes a loud noise when running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgs453q2
May 15, 2010 | Amana NDE7800AY Electric Dryer
Dryer screeches
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 14, 2010 | Amana NDE2330AY Electric Dryer
Without knowing what you mean by "a loud noise", I am going to say it sounds like the blower wheel has come loose and might need replaced.
Mar 30, 2010 | Amana NDE7800AY Electric Dryer
Loud screeching noise at times when in use!
Normally loud screeching noises come from the drum rollers being dry.
They need lubricant, or replacement
Sep 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Amana DLE330RAW Electric Dryer Logo
1,476 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
