Question about Electrolux Featherlight Gas Blower, 150 Mph, 300 Cfm, Weighs Only
Model # WT 200 LE won't start and run properly
I used the leaf blower quite normally one morning, then stopped for lunch. Afterwards, it would not start and run properly. With the choke closed (full choke) and throttle wide open, it will occasionally start and run for a few seconds before stopping. If any other settings are tried, there is no response at all from the engine. I have checked the gas, gas filter, and spark plug action, and all appears to be okay.
It would seem that fuel starvation is the problem, but not sure how to check this. could you let me know what you think please, and I can try to repair the problem. I'm fairly mechanically minded, and am able to take the unit apart if necessary.
Thanks, I look forward to a reply.
Peter Westwood.
3 Suggested Answers
SOURCE: mcCulloch bl150 will not run once full choke is
Hi
You will need to clean carb with carb cleaner and install a carb repair kit.
Sam
Posted on Jan 07, 2010
vetteman3002
  • 2299 Answers
SOURCE: BLOWER STARTS OK, THEN RUNS
1 803-649-1381 That is the number for the Phelon company. They will have a new coil for you.
Posted on Jan 12, 2011
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
Whats the proper compression on a craftsman 200mph leaf blower?
Most 2 cycle engines need at least 90(ish) psi to at least run. Most need more to run correctly.
Oct 20, 2014 | Craftsman 25cc 200 mph / 430 cfm Gas...
Won't start
This engine may well have seized, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing and the machine will have to come apart to assess the damage.
May 16, 2012 | Poulan Pro 25CC 2Cycle Gas Blower
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
Brand new echol pb250 leaf blower. used it twice then hard starting afterwards
Hi, Check that your air filter is clean and that the choke is set properly. Otherwise make sure your fuel mixture is accurate. Hope this helps.
Nov 15, 2010 | Echo Garden
Won,t start When I used it last it lost power and i had to run with the chock out.Than it quit,and would not start again
The carburetor sounds like it needs a rebuild kit. I would have a technician do a compression test on the engine. It needs to be at least 100 psi to run. Anything lower than that you are looking at an engine rebuild.
Good Day.
Oct 30, 2009 | Homelite 'Yard Broom' Leaf Blower
What type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Sep 05, 2009 | Poulan Garden
My toro blower stopped working after only 10 minutes
Hi, normally when an electric motor smells of burning the damage is done, if it's new you need to get it fixed under warranty, trying to repair it yourself will void warranty
Aug 30, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Poulan wt 200 blower, no spark
are you sure there no spark sometimes u cant see it in daylight. if there is no spark you need to trace the wire down inspect for damage and inspect for loose/rusty connections. then let me know
Feb 26, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Electrolux Featherlight Gas Blower, 150 Mph, 300 Cfm, Weighs Only Logo
Top Electrolux Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
