Question about Zenith P42W24B 42 in. Plasma Television
Zenith Problem I am trying to fix this TV from pure learning and curiosity i own a P42W24Bx Zenith Plasma Tv and maybe two months ago it lost the picture, and the only thing i have on the screen are Strong Red Green and Blue Pixels appearing randomly on the screen, usually grouped together in the middle lower part of the screen. Any one have an idea where should i start. I would really like to try fixing it and spending more money on parts than give it for fixing and not learning anything.
  • Anonymous Mar 23, 2014
    I am unfamiliar with this type repair
  • 4,234 Answers
It would help to know what the initial symptoms were. Or did the set just die with the result as you posted? In any case, first go over all of the boards and resolder any connections that appear grainy or have rings. That is the best way to start. Check the set after that to see if there were any changes. That should eliminate any bad connections as a problem. Next look for any burned or charred areas. Those are the areas where components can change values and cause problems.
Let us kow what you find so far.
Dan
Posted on Apr 23, 2008
How do I get Netflix app on my TV
Go to your menu then apps select netflix and sign in thats if your talking about a smart TV
Jun 15, 2014 | LG 6871QYH027B Refurbished Y-Sustain...
My tv lost the picture but the sound was working. i then turned the tv off then on. nothing happened. the red light flashes to green then to red with no clicks and or no sounds. i wasnt in the room at the...
I had the "pop" happen to me about a month ago. Sounds like the same symptoms as you list. I searched online to find the most common fix to the the Y Sustain board. You can find this part online for about $150. I have used rivervalleyelectronics.net. Ultimately, I chose not to fix my tv and bought a new one. Before trashing the TV I removed all the boards and have them available for sale if you are interested. I will sell all the boards, including speakers and cooling fans for $150 plus shipping. Contact me if interested.
Sep 28, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
My zenith plasma tv popped real loudlike a car backfiring and then the tv picture went black. power on green light wil turn on but it automatically cuts itself back off to the red light
There's an over current fault in the power supply or the Y-sustain convergence board. The loud pop was either a capacitor or pico-fuse breaking from excessive current overload. Sounds like 2 or 3 mosfets have shorted at the gate ends. Plasma TV's always have this problem because they generate too much heat and the components cant take the load conditions. Make your next TV an LCD...
To fix this problem have your local repair shop do it for you.....
any questions please ask.....
Jan 20, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
Dark and snowy Screen on my Zenith Plasma
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Oct 16, 2017 | Zenith P42W46X 42 in. Plasma EDTV
A large pop and I lost my screen, it turned black
Its not the CRT, its the Y Sustain board.. This happened to mine 30 minutes ago.. and has happened to every owner of a plasma tv that uses the toshiba Y Sustain board..
Jul 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
3 loud pops and picture faded away
ours was off all day and it pop 2 times and now no picture at all.
Jun 01, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith p42w24bx
u can buy tose on ebay set of 10 for 20 bucks gold bnc adpoters ok
Jan 31, 2008 | Zenith P42W24B 42 in. Plasma Television
After 20 months old and now dead
I purchased this tv 2/06 and it went POP in 04/07. Less than 60 days after my warranty expired. Went back and forth with Zenith for several months. I refused to take NO for an answer. Customer service stinks and you have to be very persistent. They eventually agreed to fix it. Repairs cost over $2000 and I have my tv back. Next time it breaks just going to throw it out. Zenith sucks.
May 09, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Screen full of moving colored lines
I would suspect bad solder connections allowing a ground to "float" It is a common problem with the model P42W24BX which I believe uses similar circuitry as your model. An experienced repair shop should be able to get you fixed up.
Dec 18, 2006 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W24B 42 in. Plasma Television Logo
196 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
