Question about Tools & Hardware - Others
I have borrowed a Max Clipped Head Stack Nailer (SN90Ch34). I promised to oil it before each use. What oil should I use? I am in rural Iowa and have access to Bomgaars, Walmart, Ace Hardware and standard gas stations, so I am hoping some standard oil will do. Thanks
  • jmcshane1 Jul 27, 2010
    yes, helpful.
    I got what I needed when I needed it.
    Thanks.
  • 553 Answers
Any light machine oil will work even 3-in-1 oil will work if your not doing mass production nailing. If you have to buy nails for the gun, where ever you buy them should have oil for nail guns. A detergent oil will cause problems so stay away from detergent motor oil.
Posted on Jul 27, 2010
Need a manual for Ridgid R350CHD clipped head framing nailer
Manual can be found at the address below. Enter your model number in the search box. Good luck with your nailer.
https://www.gardnerinc.com/manuals/
I found manual at the above address for my ridgid full round head nailer.
Nov 08, 2012 | Ridgid FactoryReconditioned ZRR350CHA...
Sears Framing Nailer #351-18320. It takes clipped head, 28 degress, paper held nails. I need replacement nails. Who made this nail gun for SEARS and where can I buy nails.
I have seen several of these guns in the shop. I have used both Bostitch and Max parts to repair. Try using nails made for duofast cn325, or bostitch n80. Both use a 28degree paper tape clip head hails. Good luck
Sep 03, 2012 | Tools & Hardware - Others
I have a dewalt framing nailer that will operate with a max pressure of 120psi. I have been using it for 2 weeks with 100psi. Now the piston will not return after shooting the first nail, unless I adjust...
Your gun should work in the 90-120 psi range to get a consistant drive depth and with a few drops, 5-6 or a small squirt, of oil at the start of work and a few more in the afternoon if you are using it a lot. It is possible to use too much oil, if you over oil it and the bottom of the cylinder chamber gets full of oil or other gunk attracted to the oil it can get high enough to interfear with the return function. Also if you are using something other than pneumatic nail gun oil it is possible some o-rings were damaged. Either way you have to remove the head cap and check the internal o-rings for damage and clean out anything in the cylinder and head chamber.
Jan 21, 2012 | Dewalt D51823 Factory Reconditioned 2 inch...
Senco sn901xo is leaking air out the top on the nailer.
This is a sign that internal components are sticking. Try spraying a light weight oil like wd 40 down the air inlet and dry firing the gun several times. If that does not work, pop off the top of the gun, that is your exhaust port. Clean the area with contact cleaner, and lube with air tool oil.
Mar 03, 2011 | Senco SN901XP Clipped Head Framing Nailer
Hear air and feel air comming out where nails come out
Try oiling the nailer. Just put a few drops of air tool oil where the air hose connects and let it set for a little bit so the oil can`t run out and try it. Sounds like it is just running dry.
Feb 04, 2011 | Dewalt Clipped Head Framing Nailer
What is the angle of the nail we use with this nailer
if thats a hitachi nr90ad, then you should be using 30 degree paper taped clipped headed nails,, never use plastic or wire collated nails in that gun,, some boxes might say 30 up to 34 degree and thats fine, also in a lot of areas clipped headed nails are no longer code, so they made the nails full headed, the head is just off set,,
Dec 04, 2009 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
When the trigger is pulled the framing nailer discharges a little air but does not activate.
First, the obvious things -- Is there enough air pressure? (90 psi) Is the gun jammed? Has it been oiled recently? Usually it is one of these when that happens.
Jul 04, 2009 | Campbell Hausfeld 3 - 1/2" Clipped - Head...
Paslode framing nailer won't shoot
Take 4 bolts off of head . Clean and lube head valve with air nailer oil. Not wd40
Apr 05, 2009 | NRS Paslode 501000 Powermaster Plus...
Tools & Hardware - Others Logo
26 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
