Question about Dell Latitude D830 Notebook
When I power my Dell latitude 830, the 2 green padlocked lights closest to the silver speaker volume switch blink constantly and then switches off without showing any display on the screen.
  • 92 Answers
Thats actually a troubleshooting code call dell to find out what needs to be replaced
Please vote me a 10 when this works
Posted on Jul 28, 2010
What are the color code of the wires to switch terminals
Almost!
the black screw is the "common" so the hot wire or the colored wire (usually black or red) bringing power in goes on to the black screw and all white wires (neutral) get connected together. you need to verify which wire has constant power when all wires are disconnected and separated first.
*White wires all connected together separate of the switch
green screw = ground or bare wire
black screw = hot wire/ wire with constant power
silver screws = (switched terminals) black or colored wire from each device being powered (eg. light) per screw
Dec 22, 2012 | Leviton 003-1755-W Three Rocker Switches
DEll Latitude D520 is not starting at all.
Remove the main battery and try again, no change! remove the ram memory one at a time, testing as you go making sure there is one ram stick in the slot at all times. If none of these work, the motherboard is the likely problem and you will need a technician to access.
Jul 21, 2012 | Dell OptiPlex Computers & Internet
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
How connect external speakers d610
Most PCs and laptops have an audio out jack, usually colored light green. Most external powered speakers have a 3.5mm mini plug that goes into this jack, usually found at the back of the case, or both at the front and back (for PCs), or somewhere around the sides, or at the back of your laptop.
You may control sound volume from your PC, while setting the volume close to the highest on the speakers, or the other way around. Your choice.
Aug 20, 2009 | Dell A215 Computer Speakers
Latitude won't switch on
hello, you will need to check the memory of your system if they are not bad. and i will also like to know if the system is making sound when you power it on.
Aug 12, 2009 | Dell Latitude D531 Notebook
Laptop switches off and doesn't switch on again.
your battery has become weak. you need to change the battery. If the issue persist, you need to service your laptop.
Dec 27, 2008 | Dell Latitude D630 Notebook
Volume very low won't go up
After I posted my problem, I browsed a bit further through the other posts and solutions, until I came across the solution of TrickyTrev34 and gave it a try. However, I did not slice the cable, but did it as follows: 1. Switch off power of the sound system on the subwoofer box. Disconnect the Front Right (FR) speaker box (the one with the volume control) from the subwoofer box.
2. Remove the silver coloured metal oval on which the speaker box stands. Now you'll see a small screw at the bottom of the speaker box. remove it. 3. Carefully remove the silver coloured metal protection plate (with all the little holes) from the front of the FR speaker box by wedging it from the top with a flathead screwdriver or other thin blunt object. Now you'll see the speaker and 4 holes with screws inside. Remove screws and speaker box opens up. 4. Inside you should see six wires (Red, Blue, Yellow, White, Green & Black). Carefully cut the GREEN wire only.
Insulate the both ends of the GREEN wire with electrical tape or heatshrink or similar.
5. Put the FR speaker box back together in reversed order. 6. Connect FR speaker back to the subwoofer box. Make sure the volume setting on your PC is very low, because when you switch back on the power of the subwoofer, you should be blasting again. As TrickyTrev34 already mentioned, the only downside of this procedure is that it will disable the volume control on the FR speaker, but who cares, your sound system works again, and you can still control the volume via the PC playback control panel and/or the multi-media keyboard if you have one.
Aug 08, 2008 | Altec Lansing Multimedia Computer Speakers
Dell latitude cpx will not power on
bad motherbord litte power tansformers on it getting to hot failed have to replace them or new bord
Jan 26, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
Dell Latitude D830 Notebook Logo
136 people viewed this question
Alun Cox
