Question about HP PSC 2410 All-In-One InkJet Printer
UNABLE TO PRINT/COPY WITH BLACK INK. BOUGHT NEW CATRIDGES
  • 35 Answers
In your print setup options right before you actually print there should be a setting to enable or strictly use black cartridge.
Posted on Jul 27, 2010
I just bought 2 new catridges (black & color) but the color ink dosen't print.
I'm not familiar with Lexmark but I think your printer is set only to print on black cartridge (black only option) There's something wrong with the settings. Check the settings, look for the color options.
May 16, 2011 | Lexmark X1270 All-In-One InkJet Printer
The answer to my error 5100 question was replace pinhead and clean. where is the "pinhead"??
You need to open the top cover, access the ink catridge case(Where catridges hung), then look for other objects that look like ink catridges but smaller, that's where the catridges feed ink (into the print heads) usually separate by colors cyan, magenta and yellow Usually Black is a lone. Replace the print Heads and clean where the dirty ink drops.
Dec 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have a Dell 926 with Error code of 1203 and unable to print
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
PLease rate me 4 thumbs
GOod Luck!!
Jul 14, 2010 | Dell 924 All-in-One InkJet Printer
Error 1203 how do I fix it?
try this solution:
Solution:
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Jun 10, 2009 | Lexmark X4250 All-In-One InkJet Printer
Can i print without color catridges
you do need both cartridges in and with ink or the printer will not print to prevent damage to the print heads from running dry. The printer normally uses a small amount of coloured ink to "tone" blacks but if you leave it set to Black only it won't do this and in the future you should only have to replace the black cartridge.
Chris
May 21, 2009 | Canon PIXMA iP1600 Printer
Printer keeps saying unable to print
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer
Good Luck
May 06, 2009 | Brother MFC 420CN All-In-One InkJet...
I installed new ink catridges and the little box still shows that the ink is low. it showed now that there is now black ink left, cant print. What do I do?????
i installed rerefilled collor catridges 831 and the little box show that ink is low and 831 ink has run out
what do i do please help me
Apr 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
HP PSC 2410 All-In-One InkJet Printer Logo
310 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
