Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
Need download of service manual for John Deere 3010 Diesel tractor..
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
  • 61 Answers
SOURCE: My John Deere 2010 tractors lift does not work.
Here is a link to the John Deere web site for the manuals.
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&tM=FR&searchCriteria=2010&submit=Search&language=english
Also,
The hydraulics on a 2010 are part of the transmission oil system. There is a bolt looking plug on the right side of the transmission, about half way up, about where your feet rest when your foot is not on the brake. Fill up the transmission until the oil is level with the top of the hole and is about to run out. Using HyGuard hydraulic/transmission oil or one that meets the same spec for the 2010.
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Posted on Sep 10, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
Where can I get a service manual for a John Deere 495 ride on mower I just need to do the basic servicing
https://www.bobcatmanualonline.com/downloads/john-deere-x495-x595-lawn-garden-tractor-service-repair-manual
Jan 29, 2018 | John Deere Garden
I need a wiring diagram for the air conditioner system on a 4440 john deere tractor. i am having trouble locating the source of power for the air conditioner compressor.
No luck finding a wiring diagram. Only thing was a complete factory service manual here - $87
JOHN DEERE 4440 TRACTOR SERVICE MANUAL TECHNICAL REPAIR SHOP NEW PRIORITY...
And the Clymer manual here - $35
John Deere Model 2510 4840 Tractor Service Repair Manual
If I were going to try to keep the 4440 going for as long as possible I'd go with the factory manual.
Sep 25, 2017 | John Deere Garden
Remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
Sabre lawn tractor 1438 gear manual
John Deere Sabre 1438, 1542, 1642, 1646 Lawn Tractor Service Technical Manual TM-GX10238 * - Download Documents / eBooks
hello arthur, john deere does not post manuals on line,this is all i could find or see your local dealer,hope this helps..
Feb 18, 2012 | John Deere Garden
Looking for hp of this engine and ware i can find shop manuals for the L3C diesel engine
Look in the yellow pages of the phone book for a john deere dealer. they will have the manual you need.
Mar 18, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
160 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
