Question about Toshiba Satellite X205-SLI1 Notebook
Pink dots on screen
Hi!
I got pink dots all over my display (on white parts only other colors are fine) is it problem with my video card or somethin else?
Thanks.
    Problem Solver:
  • 18 Answers
Could be try connecting to an external monitor using the vga port. If the same problem appears on the external display the problem is most likely the video card. You may wan to update the display drivers.
Posted on Jul 28, 2010
Blue and pink dots displayed on screen
Looks like the display has developed some problem. Try changing the input device to some other like a DVD player, VCR etc. If the problem persists, this might require attention by a qualified service technician.
Jul 13, 2012 | Sanyo DP26648-R 26 in. LCD TV
If a laptop screen is changing colour to pink, what is the solution?
More than likely you will need a new screen. It could be the screen or it could be the video card inside the computer. Try connecting another screen to the laptop to isolate the problem. Borrow a screen from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without the changing color to pink then your video card is ok and the problem is your original screen needs to be replaced. If the Borrowed monitor displays the same pink colors then your video card inside the computer is bad.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 29, 2012 | HP Computers & Internet
My laptop benq r56 work with wierd coulours white screen
Here are some steps which you can try.
- Plug in an external monitor and check if you get the same colors on the external display.
- If you get the same display, install an updated driver for your video card. But if still the same, your video card needs to be replacement (if dedicated) or your motherboard needs to be replaced (if integrated).
- If you external display works fine then the problem is narrowed down to the LCD. Either the LCD inverter or the LCD cable is failing and needs to be checked/replaced.
Hope this helps.
May 27, 2011 | BenQ JOYBOOK R56 154 WXGA CCFL Glossy LCD...
The display on my L675 S7048 is flickering badly. My whites turn pink, and my blues turn green. I see it when windows starts, even the Microsoft logo has tiny green dots all around it. When I connect an...
WHITE is a mixture of the three "primary" colours.
If one of the colours is not working, then WHITE turns PINK.
So, either your LCD display is malfunctioning,
or the "data" cable between the LCD and the motherboard is malfunctioning (not transmitting all 3 signals),
or the video-card embedded into the motherboard is malfunctioning (not sending all 3 signals).
This is nothing that you can fix by yourself; take your computer to a qualified technician, for trouble-shooting and repair.
Jan 19, 2011 | Toshiba Satellite L675-S7048 Notebook
Display problem with colors
Check the display on the external monitor. if the display if fine, you lcd needs to be replaced. if the display is the same, your computer mother board has gone bad.
here is what you can also try before calling Dell.
Turn off your computer.
now, press and hold the Fn button at the bottom left hand corner. and then turn on the computer. kepp holding the Fn key down untill you see Pre boot self assesment. it will check all the hardware problems in the computer. After 2 minutes it will show you a rainbow. if the colors are fine press Y else press N. it will give you an error code. call dell and give the error code and get the LCD repalced.
Sep 24, 2009 | Dell Inspiron 6400 Notebook
ACER 3680 2022 LCD SCREEN PROBLEMS
It may not be a problem with the lcd.
This is most likely a problem in the video card of the laptop.
but you can test it out, if you plugin a extra screen to the laptop to see if the white dots come to the other monitor aswell.
If you see white dots in both of the screens this means the video card is about to fail. and would need to be replaced.
If you don't see any white dots on the external screen then the problem is in the lcd.
You can call bestbuy they should give you another phone number to call for repairs / parts.
Jun 10, 2008 | Acer Aspire 3680 PC Notebook
LCD Monitor Half Screen Pink
sounds like a color balance issue. Check the menu, do a degauss...and then check for the color temperature (reset for default)..
Got backup?
Feb 10, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Toshiba Satellite X205-SLI1 Notebook Logo
556 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
