I have a fujitsu fi-4340c scanner and when i scan a document some of the letters are not legible. i need to know how to correct this problem.
    Guru:
  • 1,342 Answers
Make sure the glass in the scanner bed is clean.
Posted on Apr 23, 2008
Backend optical error
check on feeder side assembly, there might loos contact on bulb or on bulb controller.
Jun 07, 2010 | Fujitsu fi-4340C Flatbed Scanner
How do i reset the pick roller counter on my 4340c scanner?
First go to this site: http://www.fujitsu.com/downloads/COMP/fcpa/scanners/fi-4340c_maint-guide.pdf and download Fi4340c PDF, look over directions on cleaning Pickup Rollers be careful with handling delicate plastic moldings. After a good cleaning Test Unit. Now left ADF unit back as to service and power off a minute or 2. This should reset and bring back the normal "ready" display.
Jun 02, 2010 | Fujitsu fi-4340C Flatbed Scanner
How can you program the scanner to scan using pdf format
Make a new scanner profile in the scanner settings to save in PDF format.
Jan 26, 2010 | Fujitsu fi-4340C Flatbed Scanner
ADF is starting the page scan about 1/2 inch above the top of the page
Pop open the cover and clean the rollers with alcohol. Your feed pad could be worn out also. Make sure the feed switch actuator is not sticking.
Jan 05, 2010 | Fujitsu fi-4340C Flatbed Scanner
Has Fujitsu fi-4340c scanner. Worked for a while then it showed Front Side Optical Alarm. I tried to clean sheet path, and replaced roller and pickup pad. Still the same error. Does anyone has the...
Explanation:
Front Side Optical Alarm only generated when start command is received or when white level reference is checked (every 50 scans). CCD output must be above predetermined slice level when reading the white reference. Slice level is set in F/W and compared to the read range values. The read range is approximately pixel 120 to 4800. If CCD output does not reach slice level the AGC tries to adjust the output of the amplifier to exceed the slice level. If any portion of the read range is lower than slice then Optical Alarm is generated. Also, it can be generated by dirty optics or reference, bad lamp or CCD.
Resolution:
If "Front Side Optical Alarm" appeared, clean the glass (small and large one) of the flatbed and carrier unit.
If the issue persists, then check if CCD harness or CR cable is disconnected? Connect the connector.
If the issue persists, then replace Front lamp.
If the issue is not resolved, then replace the Control PCA or Carrier unit or Optical unit.
Pls acknowledge if the issue is resolved.
Regards,
Tech Satya
Dec 08, 2009 | Fujitsu fi-4340C Flatbed Scanner
Fujitsu scanner horizontal black line
This can be because of the Fuser Unit or the Catridge and if you can see any mark on the rollers that means it needs to be replaced.
Aug 11, 2009 | Fujitsu fi-4340C Flatbed Scanner
Fujitsu fi-4340c scanner not scanning all of back side of page
these rear camers get the board that has the CCD chip on it come loose from the camera. take off the ADF cover, at the from of the rear camera you will see the board held on with 2 screws, there have probably come loose. you will need to tighten them up with the board in the right place to allow the image from the camera to be focused on this chip. it will take you a while to get it in the correct place, but once you have it correct, the image will be perfect again. let me know how you get on
Jul 08, 2009 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-4340C changing the bulb
Open up the ADF ****.
Remove Two Silver screws holding front
of top cover.
Remove screw from ADF release button.
Pull back of top cover to unclip.
This will enable you to see the rear lamp bay
and camera unit.
Lamp is situated under Camera unit.
ADF = Auto Doc Feeder.
Jun 09, 2009 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-4530C
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
Sep 04, 2008 | Fujitsu fi-4530C Pass-Through Scanner
Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
