FixYa.com
Tags:
Brother GeoBook NB-60 PC Notebook
Display problem with Geobook NB60? (by 2 users)
By Beresford - usenet poster
I have a 6 month old Geobook NB-60 which has just started losing the
bottom half of the picture on its display.  Not being familiar with LCD
technology, I don't know what's going on, but the bottom half of the
screen has vertical white lines going through it.  If you leave it on, the
picture improves and gradually becomes normal, but it seems to be taking
longer and longer each time I start it up.
What's broken?  and where do I get this thing fixed?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by kgkg_gkgk, posted on Jul 12, 2008
good
Best Solution
posted on Aug 10, 2005
FixYa! (100)
2Pansy
2Pansy - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This happened to me too... The it didn't affect me too much because I use an
external monitor 99% of the time. I found that put ting the screen at different
angles helped. The problem only got worse so I took it into get repair on
Monday... I still don't know what the problem is...
Doug Miller
rellimg @aol.com
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
Ellen B. Edgerton a ??crit dans le message <6hn5er$ @newstand.syr.edu>...
Ellen,
Maybe nothing is broken, but it is difficult to say.
IMO, familiar or not with the technology, it's not up to the customers of
Brother products to fix this type of problem. Brother products are targeted
to the mass, therefore to non-technology-aware people. That's why the
GeoBook uses the Geos OS and applications which are easier to use than the
Windows environment.
That's also why my wife is still using NDO and her Geos-based Zoomer, which,
in that sense, is similar to the GeoBook.
Obviously, you should return it to the retail store where you bought it.
IMHO, this should be covered by the warranty, at no cost for you, unless you
let the GeoBook fall on the floor or if you twisted the screen too much.
Sorry to be of no "technological help".
Philippe.
Solution #3
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
Sounds like the screen is broken.  I would call Brother's 800 support
number and see what they say.  I've heard that they're pretty
responsive.
John ;-)
Solution #4
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
Hi!
1) Did you place something that generates heat on the Geobook
   cover when it is closed?
   For example, if you place the power supply on top of the
   cover of the Geobook when you charge the battery this will
   happen. This because it generates heat and will warm up the
   liquid crystal in the screen. I know because I had this kind
   of problem myself on a laptop (not Geobook). The solution is
   to take away the thing that gererates heat. The problem will
   disappear when the temperature goes back to normal.
2) The screen or the electronics is broken. Contact Brother for help.
   Check www.brother.com. Go to the US-pages. There you will find
   information.
Best regards,
Hans Lindgren
Can you Help with these PC Laptops problems?
PC Laptops
Runtime Error! I can't use IE?
I installed windows live one... Answer This...
PC Laptops
Gateway MX6453 or MA3
I've had the same problem with... Answer This...
PC Laptops
HP 1 long and 2 short beeps
Hi i am having that problem...... Answer This...
PC Laptops
pavo
pomagajte molim vas!!!!... Answer This...
PC Laptops
md41349
did you managed to get around... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
