Question about Canon ImageRUNNER 1670F Copier
Paper keeps on getting jammed on my canon d860 copier . was todl the fuser needed to be changed. Would this solve the problem adn for how long? I am told cost is 125$ for the fuser adn 75$ to install . IF fixed , how long will copier last befor eanother problem comes up?
  • 1,219 Answers
if you change the fuser asy by the book it goes about 80000 to 100000 copies.
If you only change the fixing film if it isnt goodly adjusted and if there is also problem with pressure roller then that would not be a good idea.
Im telling you these without seeing the machine or without knowing your monthly volume of copies.
These is small volume machine for "home usage", if you want quality and better machine buy Canon ir 3225N. These is serious office machine, with extended parts life.
Hope that helped!
Posted on Jul 29, 2010
Paper jammed at exit rollers of Canon D860. Paper
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
May 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
Sounds like there is a papper jam but I can not see papper. Copies are coming out crumpled.
These machines use a fuser film. When they get torn or go bad they make a paper crumpling sound. When this happens it also causes wrinkles and creases in your copies. There may also be areas of your copy where the print will rub off. This means it is time for a new fusing unit. They are not cheap and removal of the old unit and installation of the new unit is not easy so plan on having a service person replace it. Just do a search for Canon D860 fuser or fusing unit.
Good Luck and Thank You for using Fixya.
Apr 30, 2010 | Canon imageCLASS D860 All-In-One Laser...
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Our Canon ImageClass D860 copier had a paper jam. We cleared the jam and did everything we were supposed to do and it still says Paper jam on the screen. We've turned it off, unplugged it and still it says...
There mite be some paper dust on the sensor where the copier indicate the paper jam is. some can air mite solve the problem. Be careful to direct can air towards the outside of the copier don't want to blow the paper dust to a different sensor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 12, 2009 | Ricoh Aficio 2015 Copier
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
Canon Copier D860, Serial# KAB50221, Received on 1/24/06
if under warrenty you'll defanetly want to send it back,usally when i see this the fuser nees replaced
Sep 18, 2008 | Canon Office Equipment & Supplies
Need Help Please
problem w/the fuser, probably the lamp is not turning on and not heating the rollers, need to change.
Jun 02, 2008 | Canon imageCLASS D860 All-In-One Laser...
Canon Image Class D860 copier purchased 2005 - KAB-15948
dog ears are usuallycaused by paper hitting something before the fuser or at the fuser. the claws or fingers that ride on the hot rollers are getting worn or are out of place.
to determine the exact location, stop the copy at different locations by
1- make a copy
2- stop the copy by turning off or openning a door
look at the paper does it have the dog ear at that location? no stop it a little further until it does.
My guess is going to be the claws or fingers on the fuser roller.
Good luck
Dec 11, 2007 | Canon DHD860 Copier
Canon ImageRUNNER 1670F Copier Logo
old marine
old marine
