Question about Mitsubishi WS-55513 55" Rear Projection HDTV
I have a mitsubishi 555413 that I'm having trouble with it staying on ... the power light is blinking and the then when you turn on it stays on about a minute then shuts off. Then it can be turned on then immediately goes off. I have tried unplugging for hours and same problem. I have read about some fixes on other models, please advise if you know what the fix would be (specifically as my husband is a novice at electronics). Thanks...
  • 11,896 Answers
That is most likely the very all to common power board failure. The capacitors overheat and burn out very easily on these. They can be tested with an analog meter. Each component has it's own power rating on them. Usually but not always, the caps on the power board will look swelled up when bad or there will burn marks on the circuit board.
Posted on Jul 27, 2010
  • 2 more comments
  • pblmt87 Jul 27, 2010
    If that is the problem what is the fix? Thanks...
  • Nate Stansfield
    Nate Stansfield Jul 27, 2010
    The power board has capacitors that can be tested with an Volt/ohmmeter. Each one has its own voltage ratings on it. The reading on the meter should match the number on the capacitor. There is also a flyback that can be tested with a voltmeter. A manual can be found on retrevo . com
  • pblmt87 Jul 29, 2010
    Any other ideas for the manual ... I don't see our model on there ... its WS 55413 ... thanks!
  • Nate Stansfield
    Nate Stansfield Jul 30, 2010
    You can get there service manual at any of these sites:
    http://www.nodevice.com/manual/newmans/V...
    www.free-service-manuals.com/.../Mitsubishi/Mitsubishi_WS-55413_Service_Manual_L69812/
    http://myfreefilehosting.com/f/961f2490a...
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
42 mitsubishi how do you know power supply is faulty?
have you tried accessing the self diagnosis feature to see how manytimes the power indicator blinks after accessing ? If so let me know the blink code and I will assist you with the issue.
Oct 03, 2012 | Mitsubishi WT-42311 42" Rear Projection...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55908 Rear Projection. Doesen't Stay on.
have you tried to access the self diagnosis feature by holding the menu and device/input buttons on the set both in together for five seconds to see if the led will blink a two digit code such as two blinks pause two blinks for a 22 error? Try that and let me know the blink code and i can assist you.
May 21, 2009 | Televison & Video
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
