Question about Indesit Dryers
Defy DTD252 autodry wiring diagram element wiring
4 Suggested Answers
  • 3074 Answers
SOURCE: DEFY AUTODRY WIRING DIAGRAM
disconnect dry and in the back of dryer in top left hand corner is your diagram, looking from back of dryer, just remove the 6 screws from the top panel at the back of the dryer Good Luck Tim
Posted on Dec 26, 2010
  • 16 Answers
SOURCE: Defy dryer, not heating
Check that you have 220v first. Your dryer will work on 110V but will not dry. You need to check all thermostats with a ohm meter (be sure to unplug dryer), they should be 2 ohms or less. Set ohm meter to 1x. If they are good go to heating element (your ohm meter should be on 1X as wel. You need to check to make sure you have continuity (however, this does not mean that it is not bad). You need to take it out and visually inspect it to make sure it has no breaks in the coil. If it does you can buy a rewire kit for runder 30 bucks for most models.
Posted on Jan 06, 2009
heatman101
  • 43501 Answers
SOURCE: Defy autodry, comes on timer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 18, 2011
Timer Defy Tumble Dryer Dtd252/ Diagram
Request the diagram from Defy.
Jul 07, 2018 | Dryers
How and where does one clean the filter on a defy autodry? I need to check as there is a warning light which i need to check as it does not want to get warm.
https://www.manualslib.com/manual/926961/Defy-Autodry.html?page=7#manual
Quoting:
Cleaning the Lint Filter
The lint filter, which is located behind
the door, should be cleaned after each
load to maintain optimum drying
efficiency.
The filter and filter cover are located
inside the door surround front.
Insert two fingers into the two large holes
and pull the filter cover free of the door.
Remove the filter mesh and clean off all
the lint by gently rubbing the filter mesh.
Replace the filter mesh and then the
cover.
Ensure that the filter is in position before
closing the door.
Cleaning the rear Air Intake Grille
The air intake grille, at the bottom rear of the machine, should be cleaned regularly to
maintain optimum drying performance.
Remove any obstructions and dust the grille off with a soft brush
Defy autodry Owner Manual Unsuitable Materials
Jul 02, 2018 | Dryers
Defy Laundromaid Electrologic 1300 wiring diagram
Contact Defy directly and request the wiring diagram.
Feb 26, 2018 | Washing Machines
I need a wiring diagram for a Defy slimline 600 TW thermofan
Request the wiring diagram directly from Defy.
Oct 03, 2017 | Kitchen Ranges
I need a expleded view for a Defy tumble dryer DTD252
Check the Sears Appliance Parts website - it usually has these diagrams.
Jan 08, 2015 | Dryers
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
Where can i find a maneul on a defy 721
Check in this two links:
- Defy AutoDry
- Defy AutoMaid
Both in PDF format.
Apr 25, 2011 | Ovens
Dec 26, 2010 | Dryers
Jan 03, 2009 | Roper RES7646KQ Electric Dryer
Dryers Logo
1,798 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Marvin
Marvin
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
