Question about HP Photosmart 2575 All-In-One InkJet Printer
My ink cartiges are new yet the printing is poor and looks stipy
    President:
  • 2,571 Answers
Use the head cleaning tool, if you dont use the printer regularly, the ink can dry on the heads and cause lots of poor printing problems
Posted on Jul 27, 2010
My printer will not print in black. I put in a new black cartrige after the old one did the same thing so I know its not the cartrige itself. I used the instructions on the printer for it to clean the...
Maybe there is fault in the software and will need a re installation. so remove your printer from the PC and un-install the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Tip
How can you clear a cartige ink jam
you can clear a cartige ink problem if it is not printing by rubbing metal part of the cartige by a eraser aur by polishing it by hot water
on Jun 09, 2010 | Office Equipment & Supplies
How do I print color
it should always print colour, do u have a colour ink cartige or just a black ink cartige in your printer
Oct 11, 2010 | Computers & Internet
I got my ink cartridge refilled but it's still saying its empty, how do i get it to print anyway?
So as MUKHTAR states, do not refill cartiges when they are TOO EMPTY as most of the new printers have a sensor in the cartige that tells when it is empty. and when that sensor fills that the cartige is empty, it stays that way, no matter how much you refill it.
on the laser printers, when you refill your toner cartige there also is a chip that is changed (the sensor) because once that sensor feels that the cartige is empty you will not be able to use that cartige anymore.
Nov 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Easyshare 5300 only prints in light yellow ink
You should check ink level, probabbly you need to replace some cartiges.
Jan 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
R220 epson printer not printing
ensure u r using original ink cartiges try head cleaning process replace all the ink cartriges
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
Can you tell my printer cartiges was finish i refil new cartige and put in the printer but printer does not work only for printing from computer but fax is working photocopy is work and sccaner is also...
Please follow these tips
1. turn off your printer for one menu t and then turn it one.
2. You should charge your ink the option may be in your Pinter software or there should a button in your
Pinter to charge your ink.Press
OK to begin charging the ink.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}you need to disable the ink level monitors afterre-filling the cartridges. go to properties, maintenance, view printer status,option and click enable status monitor once
Nov 22, 2008 | Lexmark Office Equipment & Supplies
Not printing red ink clearly
i think problem could be solved
take out the cartige and the cartige holder , spray them with glass cleaning solution and replace them back
Nov 11, 2007 | Epson Stylus Photo 900 InkJet Printer
Dell color cartridges
this sounds wierd to tell you
take out the cartige and if you can take out the cartige holders ( try to reach for the place where the ink flows out) spray it with a glass cleaning solution and let it pass inside where the ink pases and believe it or not it will clean properly the ink passages. try to clean the bottom of the cartige too.
some 1 trid it infront of me and it worked.
ps: an unproper positioning of the cartige will cause the printer not to work.
Nov 09, 2007 | Dell 924 All-in-One InkJet Printer
Not Printing
the problem you all have could be from the ink cartige or from the ink cartige holder , take out the cartige from the printer , if you can take out the cartige holder out too , spray the cartige holder with a glass cleaning solution so it pours out from its bottom side , spray the ink cartige bottom , wipe it with a tissue then swing it hardly downwards so ink is poured from its bottom then wipe it with a tissue .
Oct 17, 2007 | Office Equipment & Supplies
HP Photosmart 2575 All-In-One InkJet Printer Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
