Sony KV32FS120 does not power up indicator light blinks I detect no voltage across relay. Do you have tips on this also is it possible to email me the schematic of the power supply cirrcuit. hoycemitchell@yahoo.com Bweddings@hotmail.com
  • 1 more comment
  • bweddings Jul 28, 2010
    Sony KV32FS120 does not power up indicator light blinks 9 times I detect no voltage.I hve checked the circuit board for 200 volts set will not engage only stand by voltage present
  • bweddings Jul 29, 2010
    i HAVE CHECKED ALL COmPONEnTS IN THE horitizonal output section and the power circuit I have the 24 volts for stand by could there be components in this section that checks good but be faulty. What could cause this to blink 5x on one set and 9x on another set what could this be on the Sony KV32FS120.
    I have two Sony KV32FS120 one blinks 5x but will not engage the other blinks 9x but will not engage I checked all conponents in the horizitional and power supply I only get 24 volts in the standby mode.It is not ckhecking for 200 volts that is required
  • 3,037 Answers
Here is the service manual for this tv at the following website link. Unfortunately I can't get you a free copy, but if you want one, then you can register at this site and download it after paying for a subscription, the site says that it has your specific manual which would be very helpful if you are able to read schematics http://www.nodevice.com/manual/sonymans/manual3534pdf/get5050.html# Since you seem to know a little about electronics, this will be a good start for you. I can answer questions that you may have, just give me time to respond to any that you post as I am not on here 24/7.
Otherwise what I can help you with is the blinking indicator light. It most likely has a pattern which is an error code. Can you please post the pattern for me (how many blinks in a row) Thank you
Let me know what you find. Benjamin
Posted on Jul 29, 2010
    Can you tell me what the indication is if there are 5 blinks then a 4 or 5 second pause then repeats itself this set will try to fire up but does not but the voltage will not hold.
    The other set has rapid blinks 9 times with a 4 to 5 second pause then repeats. this set only have voltage in the stand by mode and never tries to fire up.
    Both are sony's KV32FS120 Can you help with this problem
    the set when the power button is initial depressed voltage tries to come up but shut downs as though the shut down circuit has been activated then the indicator light begins to blink 5 times rapiddly pauses for 4 to 5 seconds then repeat continously.
    the other set when power button is depressed no other voltage is indicated to come up IE.. regulator high voltage etc.only stand by voltage is presentthat is the 24 volts 5 volts it then begings to blink rapidly 9 times then pauses for 4 to 5 seconds then repeats.
    Both sets are sony's KV32FS120
  • 10,594 Answers
How many times power indicator/ standby light blinks with 3 seconds long pause?
Click HERE to download service manual free copy that has all schematics, parts list info, I hope that will help you to fix this tv.
Let me know if you face any trouble in downloading service manual.
Thanks.
Posted on Jul 27, 2010
  • 6 more comments
  • bweddings Jul 27, 2010
    The KV32FS120 blinks 5 times stop and then starts to blink again
  • Shahid Electronics
    Shahid Electronics Jul 27, 2010
    5 times standby light blinks.
    Check +200V on circuit board that fixed on tube end. You can check these volts before tv goes to standby/ shuts off.
    If 200V are fine then adjust Screen Volts as control knob is located on flyback transformer. Upper knob is focus control and lower is screen control.
    Solution does not apply for this set the relay does not engage so you can not get 200 volts or any voltage other than the stand by voltage.
    You need to push power or channel button on tv remote to turn it on to test voltage, tv will go to standby in few seconds but you can measure +200V on crt board.
    I'm Sony tech and do this kind of job daily.
    used the remote now set blinks 9 times, set does not come on only voltage that comes up are the 24volts and 5 volts but relay will not engage . Standby voltage present but regulator voltage will not kick in.
    Did you downloaded service manual from link I provided you earlier?
    Service manual has error codes details up to 5 blinks. Unplug tv from wall socket for minute, replug back in and turn it On.
    Shahid Electronics Jul 28, 2010
    ok, no problem.
  • pragmaticjim Sep 24, 2010
    I also have a kv-32fs120 that blinks 9 times. The standby and 24v are present.
    When I pull pin 66 of ic001 down, the relay clicks, and I can turn the TV on with the power switch. Everything seems to work ok, but I don't run the TV that way for more than a few seconds at a time.
    I am not looking forward to changing IC001. Any suggestions on what to check?
I have a SONY kP51WS520 thats stuck in standby mode..it blinks about 10 times
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section. Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multi-meter to check the continuity or shorting in components, if so detach from circuit and test. If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly, the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Check for tips to check the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Nov 01, 2011 | Sony KP-51WS520 51" Rear Projection...
Sony kv-36hs510
Blinking light* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board), you need to replace or get it serviced by the company if under warranty or get it done tv repair personal ,if like to perform DIY then I would recommend going to the following link and getting the service manual so you can see first hand dis assembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a newD board. heres the link.
http://servicemanuals.vstore.ca/
Good luck..
Sep 09, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
5red blink sony
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Thank you for using fixya.
Sep 21, 2011 | Sony Televison & Video
I have sony model no kv-bm14m40 it blinks two times.The voltage on the CRT base which was supposed to be 200 is 235.what do I have to do to solve this problem. I appreciate any help JJ
Hello
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits
The switched output voltage from the power supply is mor than normal. The normal secondary main supply voltage to this set must be around 135VDC. It is now been exceeded that limit, and the overvoltagg; current protection circuits in the set detects this situation and gives you tow blinks as its indication.
Normally, this fault is common to most of the Sony Trinitron sets. The main cuse for this fault is loose solderings at the SMPS power switching section. Just resolder most of the supected solder terminals by applying a little more solder, without making any solder bridge short in between the adjecent solder points. If needy, replace the secondary voltage filter capacitor [the electrolytic capacitor fitted across the 135VDC to ground. This must help you. OK.
Aug 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When i plug in my tv it has a sound then it stops, the on light just blinks and it dose not stop
Is the blinking light the power indicator or the lamp indicator? Is it sending a diagnostic code such as five flashes and a pause, repeated? If the lamp indicator is flashing, the bulb is burned out.
If the sound does not come from the speakers, and is not a soft click from a relay (electromagnet-operated switch), but is a crackle, thump or squeal, then you have either a high-voltage breakdown or a shorted component in the power supply.
Other possible noise sources are the lamp cooling fan or color wheel (spinning disk).
Whatever is going on, the set has detected a fault and is turning itself off to protect other components. The noise could be normal startup sounds that you don't notice in normal operation because they aren't masked by audio from the program material, or it could be a cutout relay in the protection system.
Oct 23, 2010 | Philips 60PL9200D Projection Televisions
My sony kdf-42we655 has 7 flashing red blinks. please help.
Audio Protect (7 Flash): When DC voltage is detected at the speaker or
woofer outputs, IC3604/pin128 (TV-micro) goes low and IC3604 turns off
the main power (AC relay turns OFF).
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Jun 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No sound no picture, the stand by light blinks four times
If you have the above model, then the four blinks indicate a backlight failure. The back light inverter board might be defective or the voltage from the power supply (+24v) is low or missing.
Let me know if you require further assistance.
Dec 30, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV auto shut off-power indicator light blinking-won't turn back on
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If you are having some problems with your Sony Television, then this post is for you. Generally speaking, when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
* 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
* 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
* 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
* 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
* 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
* 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
* 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Jul 08, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Wega 42" LCD HDTV
I've been trying to find th thermal fuse on a 42we655 for like 3 weeks...It's not under the lamp...Any one know where it is?
Thanks
Aug 31, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Televison & Video Logo
1,005 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
