Question about Frigidaire FRT18G6J Top Freezer Side by Side Refrigerator
My refridgerator is not keeping things cool like it should. I have tried turing it up but it does not get any cooler. Also in the back top right hand corner there is a hole that apparently is part of the hook-up for an ice maker. The hole was covered with a sticker when new but the sticker was removed. Could that be part of my problem along with the heat of the summer ?
  • Frigidaire Master
  • 1,769 Answers
If that hole goes all way through back of unit to inside freezer, and it is open, yes it should be closed up.
Posted on Sep 10, 2017
  • 833 Answers
SOURCE: Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Posted on Dec 24, 2007
tborn6
  • 700 Answers
SOURCE: We have a Coke Cooler (True)-- not cooling, icing over
thes are pretty well built unit, did you check th see is the evaporator fan motor is running at full speed" All that you may have to do is clean the evaporator and maybe change out the evaporator fan motor. True has a special one and you cost should be arouud 75 dollars wholesale.
Posted on Dec 23, 2008
  • 8 Answers
SOURCE: fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Posted on Feb 20, 2009
  • 40 Answers
SOURCE: Frigidaire #FRS26ZSH : Fresh food not even cool.
that is a defrost problem need tech to one of a few possible problems you can defrost unit completely for 2 days and it will work great for a week or so
Posted on Feb 23, 2009
heatman101
  • 43501 Answers
SOURCE: Refrigerator not cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 29, 2010
How do I know whether a thermoelectric cooling system is better for me than a compressor?
This depends on several factors: how much wine you keep on hand, where you will be putting the cooler (cool/warm room in the house) and if you are buying a freestanding cooler/built-in. If you never have more than two cases, plan on keeping the cooler somewhere it won't get too warm and you want a freestanding cooler, you should look into purchasing a thermoelectric cooling system.
Jul 31, 2012 | Furniture
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
My refridgerator freezer stopped freezing but when I turned the knobs to cooler the fridge kicked on and it worked fine for about a week. It then did the same thing. I turned the knobs to cooler and it...
i got a fridge have the similar problem,the upper part is cold ,the lower part is almost nothing at all,i found out the problem is ,the upper part is sharing th ecooling system to the lower part ,and the porblem is the passange is block by ice,so the cool air cannot get into the bottom part,clean the ice completely and check it again,remember it ,don't turn the fridge too cold,it helps not happened again for my case.good luck for u
Jun 17, 2010 | Refrigerators
Haier refrigerator freezes in freezer but does not get cool at all in the cooler section
my refridgerator freezes too much in the freezer and does not get cool in the cooling section
May 30, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Top of the refridgerator is not cooling, but the bottom is still cooling and so is the freezer.
if you have a side by side then check the fan in the freezer if it not working you will need to replace motor
Sep 20, 2009 | Refrigerators
Wine Cooler Doesn't work anymore
All cooler have a condensor and it does need to clean out from time to time , when the cooler doesn't work -doesn't cool- this is the first thing to look for clean it and see how it goes, it is a normal maintainance to keep the cooler working . God Bless and have a nice day
Jul 27, 2009 | Franklin Industries FBC360D Beverage...
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
To cool the compressor?? I do not have a problem, this is just a general discussion question I'm throwing out there. Every fridge I've ever owned, the compressor gets very warm/hot after running. I have a...
Some compressors are designed to be externally cooled some are not.
They have to process the refrigerant to certain pressures to operate correctly.
The specific condenser and expansion device do the rest.
By cooling a compressor artificially you make it work harder to do its' job.
Cooler is not always better.
Feb 22, 2009 | Frigidaire FRT15G4B Top Freezer...
Wine cooler doesn't cool
you need to turn the temp. setting all the way up,use a rag to hold the fan,now see if the compressor. is running,let me know-mike
Jul 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Not cooling
First check to see if compressor is running. If compressor is running and no cool, then you might have a loss of freon in the system. If it's not running, it might be electrical or a sensor telling it not to turn on. Let it sit unplugged for an hour to see if it can reset.
Grease most likely dried up on one cooling motor. If the motor hasn't burned up, you can try to re-oil the motor. Sometimes they have an oil slot on back, then spin by hand until it becomes free. Be careful not to get your hand caught in the blade when running.
Good Luck and Hope you fix it!
Apr 23, 2008 | Hamilton Beach Water Cooler with Storage...
Frigidaire FRT18G6J Top Freezer Side by Side Refrigerator Logo
50 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
