Question about Samsung Prostar 816 Phone
How do I brighten the LCD display? It's so dim I can just barely make out the date and time.
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
There is no way of brightening the LCD however the Prostar 816 display phone, however it is designed so that the display tilts to deflect the lights. I'm sorry this isn't really a help. however I have uploaded 1 of almost 70 videos which may help you with any further issues on the Prostar 816. more tips on training on
http://www.abbeytelecom.com
Posted on Jan 14, 2011
Lcd backlight off
Check inside the unit, this sounds like a loose connection in the wiring, sounds like the earth wire.
Bruno
Sep 06, 2014 | 2003 Yamaha BT 1100 Bulldog
Pioneer deq-7600 lcd very dim, lcd problem?
The LCD display is failing, or the driver ic is the issue, or the B+ is to low causing the dimming effect, a resistor gone high in value would explain this.
Mar 19, 2012 | Pioneer Audio Players & Recorders
LED on my Sony ICFC218 is dim
i found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Dec 02, 2011 | Sony ICFC218 Clock Radio
Samsung 46 " lcd backlight dims and brightens by
there is a light sensor that is for the backlight thatg if you refer to your manual you can find out how to turn it off
Mar 10, 2011 | Samsung LN46A650 46 in. LCD HDTV
Display is dim and I cant find a way to brighten it
press and hold fn, then press F7 to reduce brightness and F8 to increase brighness.
That is Fn + F7 or F8.
Take care.
Mar 08, 2010 | HP Compaq Presario V2000 Notebook
Monitor is dim
Sounds like your inverter is failing. The inverter takes the dc power from the battery and charger and converts to high voltage AC current for the backlight lamp inside the screen. When the inverter starts to fail, the display will sometimes blink, dim out over time, flash just get dark and stay that way.
Sep 28, 2009 | Toshiba Satellite A215-S7422 Notebook
MY A100 LCD SCREEN IS VERY DIMM WHEN VIEWING DVD howto brighten
You can brighten or dim the LCD screen by pressing the Fn key plus another key with the a sun symbol eg the UP & DOWN arrow keys or one of the F3 to F12 keys - it varies depends upon the model of the laptop.
If you cannot vary the brightness of the LCD screen the you have a faulty backlight.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Dim LCD display
ccfl tube goes down or inverter cirucuit is fail
need to replace it
Feb 02, 2009 | Sony VAIO PCG-K23 Notebook
Display is very dark
Dim screen is usually caused by a bad inverter board especially if you get video to external monitor. Usually cost $100-$200 depending on laptop.
Hope this helps!
Jun 11, 2008 | Toshiba Satellite M45-S331 Notebook
HP dv1000 monitor just stopped working.
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Jun 05, 2008 | HP Pavilion dv1000 Notebook
Lands Phones Logo
141 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Brett Duxbury
Brett Duxbury
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
