Question about Technics SA-AX730 Receiver
Fan is not working? - Technics SA-AX730 Receiver
    Problem Solver:
  • 11 Answers
Are u sure the fan is not working because on my ax730 the fan will only come on if im booting over half volume
Posted on Aug 02, 2010
Radiator fan not working
Hi, If your radiator fan not working change fan switch. If you know where is the fan switch disconnect it and see if the fan work when you put car on. If not check the fusem, fan relay and fan power problem.
Mar 03, 2014 | 2008 Cadillac Escalade
Dodge Stratus R/T fan doesn't come on while car is running and car is getting hot.
FAN NOT WORKING
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.
Test volt at fan relay and fan motor.
For more help, I suggest you to go through the troubleshooting links mentioned below:-----
Click the link below: ------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
These will help.
Thanks.
Nov 27, 2012 | Cars & Trucks
Fan won't work
Bother are to be inspected.Test volt at fan relay and fan motor.-------------
For more help,i suggest you to go through the troubleshooting links mentioned below:-----Click the link below:------
------------These will help.Thanks.
2004 grand marquis fan quit working..replaced fan but still wont work
is this the blower motor fan for you heating and A/C or the cooling fan cooling fans have a relay blower fans are fused but controlled from switches inside as well as fuses
Aug 27, 2012 | 2004 Mercury Grand Marquis
How do i test the fan if i already replaced the relay and the fan switch and it still doesn't work? What else could be the problem?
you could apply 12v battery power directly to the fan itself...there should be 2 wires coming from the center of the fan, follow these and you should come to a plug that you can un hook as if to remove the fan. on the fan side of the wires, hook them to 12v power, one wire + one to - if the fan does not turn, switch the wires polarity and test again. ( the fan should run either way, polarity just dictates direction of rotation) if the fan spins, the problem is on the car side. if not the fan itself is suspect. test vehicle side with known good fan or test light.
Mar 24, 2011 | 1992 Toyota Corolla
Ceiling fan won't run but the light does work. Fan has worked in the past but now just the light works. Why would the fan not work? This is a Hampton Bay Northport III ceiling fan ( product of Home Depot)
mcdevito75 here, You say fan worked in the past, That tells me the fan has not run in over 1 month if so, try this. First, the fan motor is a sealed unit, without running the fan in over 1 month it may be a little stiuck, put the fan lights on, and pull the fan chain just once and turn the fan blades themselves just a little to get thm started. also verify fan switch itself is good, Chain switch should have the familiar click click to it. If not the fan swich could be bad.
Jul 20, 2010 | Hampton Bay 52 In. Northport II Fan, BN
One of my fan is not working 1999 Honda Accord
Which fan is not working, A/C or Radiator? Check fuses, if good disconnect fan plug, direct wires from battery to fan to check fan, if fan does not work change. If fan works check water temp sensor for radiator. A/C fan only comes on when A/C is switch on. Like wise radiator fan only comes on when water reaches a certain temperature.
Jul 05, 2010 | 1999 Honda Accord
Fan
You have to check the main relay fan fuse relay and disconnect the fan and try it directly to make sure the fan motor is fine if all this is well into the cavity where the thermostat is a thermal switch that sends it relay the signal to the fan you can disconnect and the fan has to start working if this works the problem is you have the thermal switch. Thanks
May 10, 2010 | 1998 Toyota Camry
LIGHT AND FAN ARE NOT WORKING. HAMPTON BAY LIGHT IS NOT WORKING
Could be a loose wire up inside the fan. I would be very careful in its use. Might I suggest getting an electrician in to resolve this issue. You do not want to battle a fire over a fan light issue.
Aug 28, 2009 | Hunter Ceiling Fan Light Remote Control
Intermittent operation of interior fan - isuzu kb/trooper
fan speed resistor block blown if fan works only on full speed (because power goes directly to fan on full speed, not through resistor)
if fan doesnt work on full speed check for power at fan on full speed with test light if power there fan faulty
no power check switch bank assembly
Aug 06, 2009 | 1999 Isuzu Trooper
Technics SA-AX730 Receiver Logo
158 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
