Question about NorStar Passport 2430 Router
Network passport router login and password information
    President:
  • 2,571 Answers
This is all i could find
Nortel Norstar Modular ICS Any **ADMIN (**23646) ADMIN (23646) Nortel Norstar Modular ICS Any **CONFIG (266344) CONFIG (266344)
Posted on Jul 27, 2010
PASSWORD ROUTER LINKSYS
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usually be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware resets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
Linksys Home Networking
Mar 05, 2015 | Linksys Wireless-G WRT54GS Router...
I am trying to set up a new computer. When I bring up my wi-fi, it asks for a "network security key". I have tried my password and the "security pin" number from the router. It won't accept either.
For this situation have every router factory reset button,
Did you try this? For password and login information write your router to google and try to find it with keaywords like "myrouter + login information"
Feb 20, 2015 | NetGear N150 / RANGEMAX 150 Router
I can't connect to my internet. I don't know the correct password.
You will need to login to your wireless router to get, or set, your network password. A typical default router IP address is 192.168.0.1, but there can be any number of possibilities depending on router type, and network configuration, and who set it up... Some routers will put their default IP Address, and password on a sticker, located somewhere on the router. If this is the case, type the default IP Address into a browser on your computer, and hit enter, or return. A web page should appear asking for login information. User name, and password. Again this information varies... Typically the default user name is "Admin" or "admin" you can also try leaving this field blank, and just entering the password found on the router. In some cases the password is actually "admin" while leaving the user name blank.
If your successful at loging-in, you need to look at your wireless settings, under one of the sub-tabs you should find a password field indicating your network password. This is what should allow you to login to your network with your Roku device.
Nov 17, 2014 | Roku 3
Just installed roku. How do I find password for Home_B698
You will need to login to your wireless router on your computer to get, or set, your network password for "Home_B698". A typical default router IP address is 192.168.0.1, but there can be any number of possibilities depending on router type, and network configuration, and who set it up... Some routers will put their default IP Address, and password on a sticker, located somewhere on the router. If this is the case, type the default IP Address into a browser on your computer, and hit enter, or return. A web page should appear asking for login information... User name, and password. Again this information varies... Typically the default user name is "Admin" or "admin" you can also try leaving this field blank, and just entering the password found on the router. In some cases the password is actually "admin" while leaving the user name blank.
Nov 15, 2014 | Roku Streaming Stick
FORGET PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usual be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware sestets and clears out the old information.
Apr 07, 2014 | D-Link Wireless N Access Point Dap-1360 -...
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
Where do i find the passward on router
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
To login to your NETGEAR router administration interface, open the following URL using your web browser -
http://192.168.1.1 or http://192.168.0.1 or http://www.routerlogin.net or http://www.routerlogin.com
Note: The actual URL changes by the product model.
You can sometimes find the login URL and default login information on a sticker on the bottom or back of the router.
Jan 30, 2013 | Belkin N1 Wireless USB 2.0 Network Adapter...
I am trying to find out what my WPA key is for my Belkin G wireless Model# F5D7234-4. The PS3 Network went down and now I have to re-enter it into the system and I don't remember what it is
Type 192.168.2.1 into your web browser's address bar. If you have not changed the default login, you should be able to click the submit button and log into the router. If it has been changed, type in your login and password information. In your router's menus under the wireless security settings you should be able to find your network's password. If it is all starred out you can put in a different password and use that for your network. Unfortunately, you then have to change this information on every device that logs into your network. Good luck.
Apr 24, 2011 | Belkin Computers & Internet
How do i set security for lynksys router/wrt54g
First you need to login to your router! To do that you will need your IP address. This will typically just be 192.168.1.1. Open a web browser (internet explorer, firefox, chrome, etc.) now type 192.168.1.1 into the address bar to bring up the login window for your router.
-----If the login window does not show up then that is the incorrect IP Address, so get on a computer that is plugged into the router by an ethernet cable and go to Start, click on Run and in the Run window type CMD and press enter to bring up the command prompt. In Vista or Windows 7, go to the Start Orb and type CMD into the Search bar, then right click on CMD in the pop up window and select Run As Administrator. Now that you're in command prompt, type IPCONFIG /ALL and press enter, now look for Default Gateway (that's the ip address of your router). Write that IP Address down and type it into a web browser.
Now that you're at the login window of your router, type in your login information. If you never changed your login information then the default information should be
Password = admin
(leave the username blank)
-------If you do not remember changing the login information, but a blank username and a password of admin does not work, then that means that SOMEONE put on a password, so you will have to reset your router by pressing on the reset button on the back of your router for 30sec, you will need a ballpoint pen or a paperclip to press on the button as it is very very small and recessed. Once reset, the login information should be no username and a password of admin.
Now that you're logged into your router, head over to the Administration tab and set up a new login password for the router so no one can login to it, except for you. You will have to type in a password that you make up, confirm it by typing it again, and then click on Save Settings at the bottom. Now a login window will pop up and you must type in your password that you just set.
Now click on the Wireless tab, in the Basic Wireless Setting subtab,set wireless network mode to Mixed. Create an SSID, this is the name of your wireless network basically. Leave Wireless Channel on 6. Now you can Enable or Disable Wireless SSID Broadcast. If you leave it Enabled, ANYONE within range of your network will be able to see it and if they want to try to break in they will have an easier time since they know the name of the network. However, if you Disable it, you will have to tell all of your wireless computer's the name of your network so that they can find it. That really isn't a big issue though since you're going to be typing in a WPA key on all of your wireless computers anyway. Now that you're done on this screen, click Save Settings at the bottom.
On the Wireless Security subtab, select WPA2 Personal for Wireless Mode. WPA Algorithms should be TKIP+AES. WPA Shared key is basically the password that all wireless computers will need in order to login to your wireless network, I stongly suggest you make it complicated with lower-case, upper-case, numerical, and special characters, i.e. iL!k3P1#, but don't use that as it is all over the internet now. Write down your shared key and store it somewhere safe. Leave Group Key Renewal at 3600sec. Now that you're done on this page Click Save Settings at the bottom.
Now you're done....Unless you want to go nuts and use MAC filtering. To do that, you will have to find the MAC address of every wireless piece of equipment, retrieve it's MAC address (that can be done in command prompt on computers, using the IPCONFIG /ALL command), type them into the MAC FIlter List and tell it to Permit Only PCs list to access the wireless network.
Anyway, now that you're all secure, your wireless equipment probably lost connection, so now you need to go to all your wireless computer/printers and set up new wireless connections using your new login informaiton.
Go to Start, click on Control Panel, in Control Panel click on Network Connections or Network and Sharing. Now click on Manage Wireless Networks, select Add, and then Manually create one by providing the information you created in your router. Remember SSID and Network Name are the same thing basically.
Hope this helps! If not, comment back and let us know!
Dec 20, 2010 | Computers & Internet
Findng or resetting my wireless network password
You can find the Wireless Network Security key after login to the Router from the Wireless settings of the Router.
Please refer the User Guide of the Router for the instruction to login to the Router or provide the information about the Router (like model number of the Router) so that we can provide the instruction to login to the Router.
Also, you can find the Wireless Network Security Key by using any third party utility like "Wireless Key Viewer" to scan and view the saved Wireless key in the Computer.
Good Luck!!!!!!!!!!
Nov 22, 2009 | Dell InspironTM 1501 Notebook
NorStar Passport 2430 Router Logo
213 people viewed this question
Top NorStar Computers & Internet Experts
Computer Links
Alun Cox
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
