Question about Toro 60'' Com Zero Turn Lawn Mower 27hp Kohler ()
I have purchased a Toro zero turn mower and can't get it to start. It has gas, I charged the battery. It makes a clicking noise when I turn the key but motor won't turn over. Is there any special way to start these mowers??
  • Anonymous Mar 20, 2014
    How to check fuses on mower
  • Anonymous Mar 22, 2014
    Steering on toro 3200 zero turn mower
    President:
  • 2,702 Answers
No,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
52 '' exmark clicks as i try to start it
do have the belts off brake on and handles out if not it will do that or battery may need charged or soilnoid could be going bad if you turn the key on and off fast it usually will turn over
Sep 16, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
TORO TIME CUTTER SS4235,NOT STARTING,NO ELECTRCAL POWER TO SWITCH
Check wiring for ground. Ensure battery is fully charged or replace. Replace spark plug. Clean or replace air filter. check oil level, all mowers have a low oil start cutoff. Bad gas? Flush out fuel tank by removing gas line, flush fresh gas thru. Reattach gas line, fill with fresh gas, always use Stabile in gas! Check fuel line for cracks and secure connection to carb. Battery should read 12.8 volts or higher. .
Aug 21, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Mower was running then shut off. And now when I turn key it just clicks.
sounds like your battery went bad...try a battery charger and see if it works that way ..if so then bad battery or not charging the bat. when running
May 19, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
Less than a year old, just clicks, battery fully charged
Check your starter solinoid, it probably needs replacment.
When they are defective they will make the noise you described
Free Answer...Please Rate Me
Apr 16, 2011 | Toro Zero Turn Rider 74366 Lawn Mower...
I have 1995 toro ridding mower.i got it not working an the battery was not charging so i got a new battery an ones i hooked it up every thing work bu did not start an it just makes a clicking noise when i...
Test the battery with a volt/ohmn meter to ensure it reads at least 12-14 volts. Check all the safety switches located underneath the seat & the mower deck engage handle is disengaged. Check all battery wire connections are soldi, not corroded. Check wiring on starter solenoid from battery & to key switch.
Oct 24, 2010 | Toro Lawn Mower With Toro Power Tools
Mower will not start. Makes a loud fast clicking noise when the key is turned.
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
May 10, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 60''  Com Zero Turn Lawn Mower 27hp Kohler () Logo
2,248 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
