Question about Health & Beauty
I'm trying to figure out if my curling iron is compatible with the voltage in Spain & Italy. It states 125V/250V & has a "UL Listed" symbol on it.
  • 4,102 Answers
Hi yes it will be fine it clearly states it will work at 125 volts and 250 volts which 240 volts in uk and 120 in rest of europe all your going to need is the plug adapter so it fits into the plug sockets where ever your going.
so you will be ok, you wont be shocking any one,
it will work exactly the same as it would normally it has a reducer inside that reduces the power down from 250 to 120 so this will work in basically any country in the world, you could even run it off a generator. so you will have no problems
Posted on Jul 27, 2010
NAD T760 FM stereo not working
Hello
There are three fuses with your NAD surround receiver.
Reference No Part Number Description
M751*AH 5120-0200-0 Fuse 5A 125V Time Lag 5x20 MM MITI/UL/CSA
M754*AH 5120-0052-0 Fuse 1.6A 250V Time Lag 5x20 MM UL/CSA
M752*C 5120-0024-0 Fuse 3.15A 250V Time Lag 5x20 MM SEMKO/VDE
Check them first and inform me which one has blown out. I'll give you detais after that. OK.
Oct 26, 2011 | NAD T760
I am re-wiring an outlet in my garage that normally goes to an electric dryer. I want it to have 30 amp 120V. Do I just leave off the red wire? And don't they make a 4 hole recepticle that will accept...
Yes on the red wire. I don't know of a 4 hole receptacle but that doesn't mean it doesn't exist. Do you also plan to change your breaker? You'll need to disconnect the red wire and cap it.
Here's a link to some instructions on how to do your project. Good luck!
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Change-existing-220V-dryer.htm
Mar 14, 2010 | Reliance Controls L1430P 30 Amp Plug
Power cord issue? Black Screen with image issue?
The powere cord you are using is fine (the cord is made to handle the 10A load, you are only drawing 1.5A). The monitor uses switching mode power supply that can handle any voltage INPUT between 100v up to 240v. More likely to be bad caps in the power supply. See example of failed Westinghouse due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Westinghouse LCM-19v5 Monitor
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
Philips 60PP9202/17F Fuses are gone
I can't believe he pulled them all, but here's a list of all the fuses and their ratings from the service manual:
S 1000 Fuse, T 5A IEC
S 1300 Fuse/Clip, 5 Amp, 250V
S 1801 Fuse, 2 A, 250V IEC
S 1804 Fuse, LT 1A, 250V, IEC
S 1805 Fuse, LT 1A, 250V, IEC
S 1700 Fuse, 2 A, 250V IEC
S 1701 Fuse, 2 A, 250V IEC
1003 Fuse, 500MA, 50V, UL
Jan 12, 2008 | Philips 60PP9202 60" Rear Projection...
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Health & Beauty Logo
55 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
