Question about Samsung DV448AEE Electric Dryer
I have a DV328AEW/XAA samsung dryer that is giving me an error message that means Heater temperature control problem?
    President:
  • 1,194 Answers
Make sure that the lint screen is not clogged, and that the dryer has adequate venting.
Next pull out the dryer and look for kinks or squishing of the big rippled six inch exhaust hose. You can take it off by unscrewing the clamp tht holds it onto the dryer and then clean it out. It may be clogged. You can also go outside to the external vent and check it for a clog.
Another thought is that the WASHER is not spinning enough water out of the clothing so that the dryer gets very hot trying to dry them.
If this does not work, you need to call a repairman. Overheating in the dryer can cause big problems. Or you can call Samsung on 1–800–726–7864.
Thanks for using Fixya.
Good luck and have a nice day.
Posted on Jul 27, 2010
Dv328aew/xaa runs about 10 seconds then stops with error code hE
Heater Error. Samsung believes only its customer support team is capable of solving the problem. If you go to www.repairclinic.com and enter Dv328aew/xaa, you may find a more practical answer.
Aug 29, 2016 | Samsung WF419AA Front Load Washer / Dryer
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
Samsung dryer dv328aew/xaa won't turn off
It seems to me that you have a defective relay in the main control board.
Oct 30, 2014 | Samsung DV328AEW Electric Dryers
DV328AEW/XAA dries one load and quits until cool
Typical 'motor over heat' or weak thermostat problem. Try starting the dryer just after it over heats. What happens..A humming sound?...motor is overheating and seized up....if quiet, could be motor as well. Check that your dryer vents are open and clear.
Oct 15, 2013 | Samsung Dryers
The dryer won't heat up. Model # DV328AEW/XAA.
check the motor if running? if running check the back ofyour unit when you see the exhaust pipe and clean it,and the filter inside thedryer clean it,if this one is ok.the sensor of your dryer or the heater is totally wort out,check the backof unit and look when place the heater?some model is easy to remove the heater at the back,just using screw driver,and easyto check,if the heater is continious coil it is ok,if split or broken replacethe new one,carefully to remove and carefully to return,make sure is the unit inunplug before anything to do.
Jan 04, 2011 | Samsung Dryers
Dv328aew/xaa dryer not heating
If the fuses at the panel are ok then could be the heater, thermostats, sensor or control.
Dec 07, 2010 | Samsung DV328AE Electric Dryer
Samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Jun 24, 2009 | Samsung DV317AEG Electric Dryer
Samsung DV448AEE Electric Dryer Logo
144 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
