Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Hi my krups xp2070 stooped working a month ago. Its 3 years old an its the coffe machine part. Problem is that when i turn it on it comes with 2 beeps after aprox 10 sec and wont make coffe
    Genius:
  • 1,035 Answers
Hi. Please try troublesooting procedure below.
Removed the espresso screen (above coffee grounds holder, 1 phillips screw) and ran 4 tank fulls of descaler thru the machine. the hard part was getting it to pump thru the machine. You need to ran water thru the hot water/steam nozzle first I could get it to run 1 or 2 cycles, removed the water tank and turning the system on for a few seconds and running pump dry (not recommended) could get it to cycle without blinking for a few turns. Ran the 4 tanks of descaler thru, then ran 4-5 tanks of water thru into a bowl until it ran thru clean.
All the best!
Posted on Jul 27, 2010
How do I fix my coffe machine?
Contact the authorized service center.
Jan 07, 2016 | Krups Orchestro Dialog FNF2 Espresso...
Espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
Nov 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
I have a krups xp2070 coffee/expresso maker just stopped working
Most likely your power module failed. Mine went bad after 18 months of operation. You can order a replacement power module and control module from a Krups service center or from SmallApplicance.com. The replacement is not easy since you have to disconnect all the electrical connections. The module is about $60. I don't know how much the service center will charge to replace it.
Jun 13, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Dead Krups XP2070
I think you are right. Most likely the power board at the bottom. I saw a post about replacing the transformer but I when ahead a replaced the power module to fix mine.
Jun 07, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Xp2070
Most likely a defective unit. Hope you got a replacement unit. Mine is working again after replacing the power module and the water flow meter.
Dec 18, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 coffee machine - new - espresso side - water goes straight into the drip tray & not thru the filter.
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Aug 03, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Machine stopped working
This machine is piece of s... I replaced two of them so far and experienced same problem.:
Machine works fine couple days
...than it start dispensing less water into the cup.
...than it stop dispensing water into cup completely and instead all water goes into the tray.
..The pump also starts occasionaly to make interrupted repetative sound.
Did anybody get it fixed?
Jan 05, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
184 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
