Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Forgot administrator's password
When I get to the command(after following your instructions), I inter in NET USER ADMINISTRATOR/RANDOM. This is not working. I have a XP Professional. Thank you for your help. Reggie
  • Anonymous Jun 17, 2008
    I need to paid my payment
    Novelist:
  • 150 Answers
Hi Reggie,
Please read the entire article before proceeding:
All administrator accounts are created equal, with equal
powers, except that the main adiminstrator account cannot
be deleted and it does not appear on the login (or users)
menu by default.
You do need an alternate administrator account to solve this
problem. You must login to a user account with administrative
privileges in order to access system resources, take ownership
of files and folders, and to change other people's passwords.
(including the built-in administrator account)
Otherwise, what would be the point of any security at all,
if you could bypass it at will.
If you can login to another account with administrator pri'vs,
then follow me. Otherwise you may have to pursue more difficult
options, as explained later.
1) Open up the control panel
2) Open up Administrative tools
3) Open up local security settings
4) Expand Local policies in the LHS folder tree
Check:
Accounts: Administrator Account Status = Enabled
Accounts: Rename Administrator Account = Administrator
this is to make sure that the admin account is enabled,
and has not been renamed. You can double click on these
settings to change them. Is you are for some reason unable
to enable the admin account, you must reboot to safe mode,
where the admin account is always enabled.
Now that you are sure that you have a functioning administrator
account, you must reset the password, since you cannot
retrieve it:
From the control panel, once again open up
Administrative Tools ---->
Computer Management --->
Local users and Groups ---->
Users ----->
Administrator ---->
Right click on administrator ---->
SET PASSWORD
This should do it.
N.B.
The administrator account will be re-created, you will loose
1) All settings and preferences
2) Access to any NTFS encrypted files the administrator
has encrypted.
3) Stored network and internet passwords (the administrator's)
4) Personal security certificates.
This procedure is different from simply changing the password,
because you don't know the original, so Windows treats it as a
hostile takeover, That's why you loose access to encrypted files.
If you have trouble starting the computer management Applet,
Run it manually:
START --> RUN --> compmgmt.msc
or
...\WINDOWS\system32\mmc.exe compmgmt.msc
Trick:
If you do not have access to an existing account
with administrative privileges, you may be able to hack in
with and old setup disk from Windows 2000, with
no service packs, or at most XP1
The reason is that Windows 2000 did not anticipate nor
respect Windows XP security.
1) Reboot from the 2000 disk, and follow the on screen
prompts to repair the system using the
SYSTEM RECOVERY CONSOLE.
2) Do not proceed to install Win 2000, make sure you
get out before it asks you to format a disk, if you get
there you missed the prompt and you have gone too far,
Reboot and try again.
3) Once you are in the recovery console = DOS like environment
type HELP, and it will give you a list of commands.
You should be able to create a new user account
(with admin or change the admin password privs)
4) The last alternative is to purchase an XP password recovery
utility, which you run from a boot CD.
Good luck
Martin.
Posted on Apr 25, 2008
Forgot administer password
Which password? Bios? Windows? Linux? Mac?
May 11, 2015 | Acer Aspire m5640 PC Desktop
How do i override admin password
Restart the PC, hold down F8 once you enter the Windows® Boot Menu choose
Safe Mode with Command Prompt, and now type in the following:
net user root /add
net localgroup Administrators root /add
net localgroup Users root /delete
The first command adds a new user called "root", the second command adds
that user to the Administrators group and the third command removes the
user from the Users group which leaves him in the Administrators group.
Once you've done, have a look at mine Password Reset Disk Step-by-Step Guide.
Direct link: http://www.itknowledge24.com/
Nov 09, 2014 | Medion Computers & Internet
Safe mode windows
if you didn't set the default administrator password, then you should
have been able to pass. However, if you remember that password, then please typed it in. Else you either need to download a third-party software that does the job, or you do the following instead.
Restart the PC, hold down F8 once you enter the Windows Boot Menu choose Safe Mode with Command Prompt, and now type in the following:
net user root /add
The first command adds a new user called "root", the second command adds that user to the Administrators group and the third command removes the user from the Users group which leaves him in the Administrators group.
Once you've done, have a look at a Password Reset Disk Step-by-Step Guide.
Sep 27, 2013 | Dell Latitude D830 Notebook
I forgot my password
Hirens really works and is free. Burn to CD and follow instructions. Tested, but had to do twice.
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode. XP only.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • Free software option would be Hirens Boot CD. This one is command prompt only. http://www.hirensbootcd.org/ Must follow instructions exactly.
Nov 22, 2012 | Acer Aspire 5610-4648 Notebook
I have forgot my user password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Nov 09, 2012 | Computers & Internet
I cant log on because i forgot my password
If you have any other user account with admin rights then only you can change the password..else you have to reinstall the operating system.
If you have a different account with admin accounts.
go to start then in run type in cmd\
you will see a black window.
Then follow the below steps:
To change a user's password at the command prompt, log on as an administrator and type:
net user user_name * /domain When you are prompted to type a password for the user, type the new password, not the existing password. After you type the new password, the system prompts you to retype the password to confirm. The password is now changed.
Alternatively, you can type the following command:
net user user_name new_password
When you do so, the password changes without prompting you again. This command also enables you to change passwords in a batch file.
Non-administrators receive a "System error 5 has occurred. Access is denied" error message when they attempt to change the password.
Aug 18, 2011 | Compaq Presario 1800 Notebook
Changed my computer password and forgot it cant get on my comp uter what can i do so i can use my computer again ty lexie
First,you can try this method.Start system and press F8 key when Windows is starting up. Then select Safe Mode with Command Prompt and enter. Choose Administrator,the default password may be blank if you don't set the default administrator password before.Then you will enter into doc Command as following.
Type " net user net user xxx 12345 /add " (xxx is the locked account name and 123456 is the new password set on this account).Then you will see the Command Completed Successfully.
Then this method can fully help you remove the administrator password,i highly suggest you this one.
1. Login to a computer that can link to Internet. Download windows Password key from http://www.lostwindowspassword.com and install it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD or a USB flash drive.
2. Insert the newly created CD/USB drive to the locked computer.
3. Reboot the locked computer and press'F2'or'Delete'to enter your BIOS setup and then followed the process of instructions. Just a few steps, the old password was removed.
Dec 05, 2010 | Dell Dimension E521 PC Desktop
My daughter change the pass word,and we cant get into the comp.isnt there a way to reboot from start up?
Nov 23, 2010 | Compaq Evo N610C Notebook
Forgot password
ok boot the computer in safe mode by pressing F8 in start up and select to boot in command promt. select administrator account and enter the following command.
net user
net user "account name" without quotes
net user "account name" *
enter new pasword
confirm password
that is all. have a nice time
Mar 12, 2009 | Dell Latitude C400 Notebook
Cant restart Vista
To activate the administrator account in Vista, follow these instructions:
  1. Logon to Windows Vista with normal user account username and password (must belongs to Administrators group).
  2. Click on Vista Start button, and type cmd in the Start Search box.
  3. Right click on the Cmd rand select Run as Administrator
  4. In the Command Prompt window, type the following text at the command line to set a password for administrator account.
  5. net user administrator (password)
    Replace password with the actual password string that you have chosen. Press Enter when done.
  6. Next type the following command and press Enter to activate and enable Administrator account: net user administrator activate:yes
  7. The process should completed with the following message: The command completed successfully
    If not success message is returned, repeat the process again.
  8. Logout from Vista by choosing Log Off or Switch User.
  9. Click on Administrator icon and logon with the password you selected. Now view system logs to see what errors were gererated.And run a good virus scanner
Jan 06, 2009 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
225 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
