Question about RCA R52WM24 52" HDTV Projection Television
Where can i find a ATC221 deflection board???
    President:
  • 2,777 Answers
You should try www.partstore.com
Posted on Jul 27, 2010
Where is the supply board to replace the capacitors ?
Need the model number of the set to help with the issue, But usually there are three caps on the deflection board if you have the ATC221, ITC222 0r ITC222a chassis rca
Mar 23, 2012 | RCA Televison & Video
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Need deflection board for Hitachi 50UX26B
Please find the deflection board priced 28$ at the following link.
http://www.vancebaldwin.com/products/?JK03161
Many regards
EngineerGR
Apr 08, 2008 | Hitachi 61SDX01B 61" Rear Projection...
I have a RCA 52"
Yes the ATC221 uses the 259296 flyback. If audio works and the on screen menu also comes up but no video its most likely a vertical deflection issue. I would check the vertical IC for signs of bad solder.
Mar 29, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
After 10 minutes power shouts off
small signal board is the most likliest cause. That a common problem with the ATC221 and ITC222 that model used both different chassis designs. www.tvrepairworld.com has replacement boards available.
Feb 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I purchased the convergence chips for Samsung PCL5415RX/XAA TV. Do I need to remove the entire sub deflection board to R&R them?
Yes, however I would be surprised if changing the two Ics will repair the set, as that chassis should always have the sub-deflection board replaced since most of the resistors will be stressed. Thats why samsung changed the later chassis's by removing the convergence circuits from the deflection board as its almost 98% certain that the deflection board will need replacement when the ICs fail with those chassis designs unless every component in the convergence circuit is replaced which will cost more than the deflection boards do. But you may get lucky but if the ICs dont cure the problem you will need a new deflection board
Dec 23, 2009 | Televison & Video
I have an RCA D40W135D with ATC221. Will not come
Sounds like the HV splitter, Very common problem with that chassis
Nov 22, 2009 | RCA D52W19 52" Rear Projection Television
My rca tv keeps changing channels automatically. It also comes on and goes off automatically
whats the model number of your set Sounds like the small signal board, very common with the ITC222 and ATC221 chassis RCA's. Respond to this same post with your mode number and I will assist you with the problem.
Sep 24, 2008 | Televison & Video
Power Problem
There are two different chassis used in that model. If yours has chassis # ITC222 then the part number will be 264102 if it is chassis # ATC221 then it will be part # 258762. The defelection board for the ATC221 is the cheapest. Here are two links for both to order. http://www.partstore.com/ProductDetail.aspx?ProductSKU=2187237&ProductType=PART http://www.partstore.com/ProductDetail.aspx?ProductSKU=7747288&ProductType=PART
Mar 12, 2007 | RCA D56W20 56" Rear Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
