Question about Dell Inspiron 530 Desktop Computer
PC was caught in a lightning storm, and now will not boot (only at random). It seems like it's not getting power, when it does it'll boot normally. But when the storm hit my LAN was disabled and I had to buy a card too. But I am not sure if it's my switch or power supply because when the PC does allow me to get on, it works like a charm (aside from the LAN on the motherboard).
  • Dell Master
  • 5,660 Answers
Test whether it is the Power On switch, or the Power Supply. Since the LAN card bit the dust, you may be looking at a worse problem, though.
Bypass the Power On switch.
If the Power Supply comes on, the problem is the switch.
[One generic ATX Power On switch, that I have found fits many computers,
http://www.directron.com/atxswitch.html
If the Power Supply does not readily come on, the problem is the Power Supply.
To bypass the Power On switch, you will be using a jumper wire on the
24-pin ATX main power cable connector.
Looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
(Not necessarily the same color, and isn't located in the same position on your motherboard, as shown in the link)
Motherboard orientation:
Processor to the top, Ram Memory slots to the right.
The 24-pin ATX main power cable connector on the motherboard, is to the near right, of the number 4 Ram Memory slot.
In case you do not have the Owner's Manual, for your Inspiron 530 desktop computer,
http://support.dell.com/support/edocs/systems/inspd530/en/index.htm
On this page left-click on -
Owner's Manual - View - Download - (HTML 3.44MB)
Left-click on - Removing and Installing Parts
Left-click on - System Board Components
(System Board = Motherboard)
Number 7 - main power connector (ATX_POWER), is the
24-pin ATX main power cable connector, on your motherboard.
Referring back to the Playtool link, you will see a wire with Green insulation on it.
This is the Soft Power On wire. (PS_ON)
A jumper wire is used to connect it to ANY Black wire.
ALL Black wires are Ground wires.
[This is a DC circuit. There is a Positive, and a Negative.
A Ground wire is a Negative wire.
The green Soft Power On wire, is a positive wire containing 5 Volts.
You are completing a circuit.
The Soft Power On circuit.
You are bypassing the Power On switch]
There is no splicing of the wires to connect the jumper wire.
The jumper wire will go down into the socket holes, of the 24-pin ATX main power cable connector.
One end of the jumper wire goes down into the socket hole, containing the green Soft Power On wire.
The other end of the jumper wire goes down into a socket hole, with ANY Black wire.
The 24-pin ATX main power cable, is connected to the 24-pin ATX main power cable connector, on the motherboard.
Just as shown in the photo to the far right on the Playtool link.
The back of the 24-pin ATX main power cable's connector, is where the wires come in.
(The front of the power cable's connector is plugged into the motherboard)
I use a jumper wire that is approximately 3 inches long. (7.62cm)
An insulated wire. Both ends of the insulated wire are stripped of insulation, approximately 1/2 inch. (1.27cm)
One bare end of the jumper wire, goes down into the socket hole of the Green wire. Right next to the wire.
It has to go pretty far down in there.
At the end of each power wire, going into the 24-pin ATX main power cable connector, is a metal terminal pin. (Actually is a round hollow metal pin)
The jumper wire's bare end Must touch that metal pin.
The other end of the jumper wire, goes down into ANY socket hole with a Black wire.
(ALL Black wires are Ground wires)
Power Supply (Computer) plugged into power, the jumper wire is inserted.
The contact is a very BRIEF one. No more than 2 seconds.
(The Power On switch is a Momentary Contact Switch)
I suggest you also check the 12 Volt power rail. Check it with everything plugged in, inside the computer, and the computer on.
You need the Power Supply to have a load to get an accurate test.
There are 3 Voltage power rails in the Inspiron SMPS.
(Switched-Mode Power Supply, or just Power Supply for short)
A) The 3.3 Volt power rail
B) The 5 Volt power rail
C) The 12 Volt power rail.
The main one to check is the 12 Volt power rail.
[Orange wires are 3.3 Volt.
Red wires are 5 Volt.
Yellow wires are 12 Volt ]
The Positive (Red probe lead of the multimeter, is connected to any Yellow wire, coming out of the Power Supply.
The Negative (Black) probe lead of the multimeter, is connected to any Black (Ground) wire.
See if there is an unused standard 4-pin Peripheral power cable.
It has 1 Red wire, 1 Yellow wire, and two Black wires.
Connect to the Yellow wire, and to one of the Black wires.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
[Multimeter function set to DC Volts. If it has it, set it to the 0 to 50 Volt scale]
11 to 13 Volts is Okay, but I prefer the voltage to closer to 12.
11 Volts indicates it's time for a new Power Supply.
Posted on Jul 28, 2010
Beeping
Thunder storms can cause control boards to go erratic. Try unplugging the refrigerator for a minute or two and after plugging it back in hopefully the problem will go away.
Apr 12, 2014 | Whirlpool Refrigerators
I have a HPp2081 and last night we had a severe thunder storm. My computer went off and when it came back on it had a White block with OSD Lockout on it. I don't know how to fix this or get it off my...
Turn the monitor off.
Unplug it from the AC power.
Reconnect it, turn it on, and see if it returns to "normal".
Do you have house-insurance that covers electrical damage from lightning/thunder storms?
Jun 23, 2010 | Computers & Internet
Takes several tries to boot up pc at opning of a day
Depending on the model and circumstances, it could be a power supply that is going bad. That is normally the issue we see. The less likely, but still a probability, is a virus or a motherboard, memory, hard drive or CPU problem.
It will only get worse, no matter what the cause. My recomedation is to have a technition take a look at it. He can test the power supply and do a memory, and hard drive test. He can look at the motherboard and see if any of the caps on the capasitors are popping up or leaking. If not then the next step would bechecking the computer for viruses and then other hardward components to find the possible culprit. My money is on the power supply. Have there been many lightning storms lately ?
Jun 22, 2010 | Dell Inspiron 1200 Notebook
My whirlpool duet washer caught on fire have you had this happen to any other whirlpool Duet washers
My LG washer caught on fire last week, but it was due to a lightning strike which took out a garage door opener and a couple of GFI outlets. Did you have any storms in the area?
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My behringer mixer phx2000 was took a lightning strike. the right speaker does not work. everything else seems ok
Should either unplug all electrical equipment during a storm or get a grounded filter to bleed off excess voltages from storms, power company fluctuation etc. Once the mixer electronics are fried you are SOL (**** Out of Luck) I'm afraid.
Sep 13, 2009 | Audio Players & Recorders
Compaq Presario Wont Boot
Hi, my name is ArmyMason, hate to tell you this, but it sounds as if you have a bad Processor. Did you recently experience a bad storm with lightning? Was their a lot of dust on the fan? Lightning could have struck the computer and killed the processor or excessive overheating of the processor could have also been the case. If it was a lightning strike I would contact the insurance agency and have them replace your computer. Reason I think its the processor is because you don't recieve any post and the fan spins for a second and then shuts off.
Feb 23, 2009 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Slow boot up. ACER
TRY TO REUPDATE UR BIOS, U COULD HAVE SUSTAIN SOME INTERNAL DAMAGE FORM THE SURGE. WHEN A COMPUTER BOOTS UP IT READS INTERNAL INSTRUCTION PROGRAM IN THE RANDOM OPERATING MEMORY. THIS FIRMWARE COULD HAVE BEEN DAMAGE AS WELL. IF POSSIBLE TRY BOOTIN FROM A DISK TO SEE IF THE BOOT TIME IS THE SAME WHN THE COMPUTER GETS THE INSTRUCTION FROM ANOTHER SOURCE
Aug 04, 2008 | Acer Aspire™ T180 PC Desktop
Instrument panel
I don't know but seems to me that electrical storm did not cause this, a car is a pretty protected environment (also for the electrical equipment) for such stuff, unless you had a direct lightning hit.
I presume that a hit will be very noticable and I always heard that cars are very seldom struck and therefor are a very save place in that respect.
If it is caused by the electrical storm , I would try to disconnect the battery for a period of time and try again before replacing computer and such.(check fuses to rule everything out)
Jul 24, 2008 | 2001 Chevrolet Malibu
Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
Someone please help
Good Day;
Two things normally happens after a L storm:1.) One must unplug TV for 5 minutes, then plug back in. 2.) Main glass fuse out, will be near a/c cord. 3.( Power regulator IC may be out. Try these first.
Good Luck!
Jun 13, 2008 | Panasonic PT-52LCX66 Projection Television
Dell Inspiron 530 Desktop Computer   Logo
263 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
