Question about Canon imageRUNNER 5000 Copier
My imagerunner5055 recently takes a very long time to warm up with the message "wait" after sending a page to print or making a copy at the copier. Prior to this we didn't a long wait time between print jobs. Please help.
  • 1,219 Answers
It could be related with your network speed. Check network.
Posted on Jul 30, 2010
WHAT CAN I DO TO MY PRINTER TO MAKE IT PRINT FASTER?
Depends on what part of printing that's slow. Parallel port may be slower than a USB or network connection. If your printer doesn't include a USB port, one may be available to add to it. Same for a network connection.
Other things that make laser printers slow is what you are printing. Text typically prints quickly, but images take longer, and large images take even more time.
Some software waits to send the first page until the last page is done "processing" before sending anything to the printer. You may be able to change that.
Nov 09, 2015 | HP LaserJet 2300 Printer
Describe 102-372 code problem in m24 xerox work centre
Solution : Power OFF the Printer, Wait 45 Seconds, Then Power ON CAUTION: If the machine is powered OFF / powered ON, all information that is stored in the machine's memory may be erased.
NOTE: Before powering OFF, make sure that all copy or print jobs have completely finished. Never power OFF in the following instances:
  • While data is being received.
  • While jobs are being printed.
  • While jobs are being copied.
  • While a scan is being executed.
  1. Power OFF the machine. The power switch is located on the front right side of the machine under the Control Panel.
    NOTE: Before the machine is powered ON again make sure the Touch Screen is blank.
  2. Power ON the machine.
    NOTE: When the power is ON, a 'Please wait...' message will be displayed. This message indicates that the machine is warming up and cannot be used. After 45 seconds, the machine becomes ready for use.
    If the issue is not resolved repeat steps 1 and 2 a second time.
Mar 07, 2011 | Xerox WorkCentre M-24 Color Copier
When I try to print a copy, display says "warming
A well documented problem. Try following the suggestions posted here
Dec 03, 2010 | HP PSC 750 All-In-One InkJet Printer
Ir3570 Takes Half Hour to start printing 3 pages - help!!!
Sounds like you have the wrong driver installed, go to canon website and download a new driver for the machine
Jul 06, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Long (25 seconds) cleaning wait after each page
You may have a feature on that needs to be turned off or there is somthing that the printer companey needs to fix.
May 01, 2009 | Xerox Phaser 6350DT Laser Printer
"waiting for report" /won't copy
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
Apr 22, 2008 | Canon PIXMA MX310 All-In-One Printer
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
Nov 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
Canon imageRUNNER 5000 Copier Logo
83 people viewed this question
old marine
old marine
