Question about Samsung AW0503B Air Conditioner
My samsung aw15ecb8 window ac keeps filling up with water inside the front then overflowing, just started in the last 2 weeks.
4 Suggested Answers
  • 43 Answers
SOURCE: Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Posted on Nov 10, 2008
hiltonjug
  • 612 Answers
SOURCE: to much water samsung sw51asp
Your problem is in your pressure switch. It's the one where you are able to set your water level or load size. It's easy to replace and cost little.
Please rate solution
Posted on Sep 10, 2009
Testimonial: "Cheers "
  • 52559 Answers
SOURCE: I have a samsung top loader model wa80g5.the water doesn't stop filling,It fills until it overflows.
then call a repairman .
Posted on Dec 27, 2015
I have a GE Adora top-load washing machine. The washer fills up and overflows with water on all settings. Any ideas why?
  • You could have a bad level sensor or a pinched/severed/unattached vacuum hose which goes to the sensor device. The washer cannot determine how much water the tub is filling so the water keeps going in. I would check that the vacuum hose is simply not connected and that would be the easiest fix. The sensor device is usually located inside the control panel area and you can start there.
Dec 27, 2016 | GE Washing Machines
Car keeps overheating
Assuming the engine is ok, no leaking head gasket or exhaust problem, you need to know if the radiator fan comes on when the engine reaches 225 degrees. It should also come on when you turn the ac on if the ac works.
Its also possible you have air in the cooling system.
Jul 20, 2012 | 2005 Dodge Neon
Icemaker overflows water , repairman has replaced the icemaker twice, after this last time, it started making 1 tray of cubes per week, then after about 2 weeks, started overflowing water again.
Good day,
If it is erratic as you describe and replacing the ice maker twice has not resolved the issue it would make sense to replace the water valve in the back rear of the machine, if it hasn't been done so yet. It's the flakiest part of the system and has the highest failure rate. It's been known to fill too little, to much, and sometimes not at all.
May 26, 2010 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
Samsung AC keeps popping breaker
use larger extention cord with thicker wiring,as short as possiable!
Jun 25, 2009 | Heating & Cooling
Washing machine overflowed
Try filling it again and stay with it, when it starts to get near the top, unplug it, if water continues coming out you need a new valve, if it stops, then the level switch inside the control panel is bad
Jun 17, 2009 | Washing Machines
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
SAMSUNG B1215J WASHING MASHINE (front loader )
Hi
i don't think the problem has something to do with the 6 months delay in using it, right now i think there might be 2 possibilities
1. now that you have just started using it,there might be a mistake in the procedure you follow, because washing machines have options of single ring or double ring, you might be taking out the cloths before the completion of the process, so go through the manual to figure it out.
2. Or if there is no mistake in the procedure, then there must be a problem in the programing of the machine. It might have been mis-programed to fill in water after the whole process, if that is the case take it to the dealer to get it right.
Feb 06, 2008 | Washing Machines
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag lse7806ace
After removing the power (easist was to shut breaker off), then replaced fuse just inside upper front left cover area by way of 2 white screws on bottom front panel. Clips secure the top into the horizontial lid panel (which you will also have to remove later if fuse keeps blowing) That worked for a coupe weeks as long as the Cycle Selector dial was always pushed in when you opened/closed the washer lid. Then the the problem returned. Only way out was to partially remove the unit from the wall and remove the lid assembly, which was much easier than first thought. Pictures attached. Tools needed are Phillips screwdriver and Nut drivers to remove the horizontial lid/panel from above the washer tub, and below the timer panel/dryer. Didn't need to remove the angled cover below dryer as Washer Door lid assembly is wholly below. Just push the dryer toward the rear, then remove two larger nuts from top left and top right corners. No nuts at rear, just clips that slide in/out. This allows lid cover to be pulled straight out (I had to remove the overflow tube on front right of tub, and one semi-rusted nut-driven screw from the Hot/Cold filler plate which is at the rear of the lid cover. That will make it easier to manipulate the cover and release the 4-pin plastic connector shown in pictures at the left rear corner. Then the entire cover/lid slides out easily as you may have to push the dryer top back to ease it out. Then flip it over and replace the switch and slide the 4 wire connector back under the plastic trip. and reverse the un-install. 4-pin connector is flat-keyed on one side, but it is tight to get to. My OEM part even included a new fuse (19.95 + shipping) Unit is now working fine for last 2 weeks.b88b41c.jpg8de8e68.jpg798b349.jpg49eb6d1.jpg6f06d50.jpg48c84c4.jpg
Nov 14, 2006 | Maytag LSE7806A Top Load Stacked...
Samsung AW0503B Air Conditioner Logo
85 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
