Question about Monaco Systems Inc. Ezcolor Software & MonacoOptix XR Hardware (Bundle) for Mac, PC
Monaco reference files for IT8 Target
Hi where do l find the reference files for my IT8 target from Monaco , there are lots of file but not with my number on, thanks
How to format
To format a hard drive or array, select it from
the Target Disk drop box. Choose the file
system desired from the File System dropbox
(internal drives can only be formatted with XFS).
Note that FAT32 has a 4 gigabyte filesize limit
for individual files. If you choose FAT32 for your
file system, you will not be able to store single
files larger than 4 gigabytes on the drive. Use of
the XFS or EXT3 file systems is recommended.
Press Select Target Disk when done, and then
Start format.
Depending on the size of the target hard disk or
array, a disk format may take several hours to
complete. Shares on the LinkStation will not be
accessible during the disk format.
Note: Reformatting a drive will erase all data
on it! Back up any data on the drive before
reformatting it.
Apr 14, 2014 | BuffaloShop Buffalo LinkStation EZ 320 GB...
Why is there an error message: Space Not Enough when trying to copy DVD?
There is some space reserved for dvd information, error information etc. So solution is make the file archive by right click on file ->proprties-> click archive. After that use winrar and compress. http://www.rarlab.com/download.htm
Aug 22, 2013 | EZ Dupe Computers & Internet
Can't find my Google icon
Fix All My Computer Shortcut Links
Computers often use shortcut links to make it easier for users to locate and open files.
These links are commonly placed in a folder easily accessible to users, such as a desktop folder.
When a shortcut is created, it is given directory information and an icon.
If the file associated with a shortcut is later moved, the shortcut may fail to locate the file.
When this problem occurs, you need to update the shortcut's directory information.
This process is often automated by operating systems, but in a some instances, you need to repair shortcuts manually
Right-click on a broken shortcut link's icon.
Select the "Properties" option. Locate the "Target" box and copy its information into your clipboard using the Ctrl and C keys.
Open the "My Computer" folder on your computer and paste the target information into the folder's address bar using the Ctrl and V keys.
If the address bar is not viewable, you may need to enable it in the folder's settings.
Find address bar options in the "View" menu under "Toolbars."
The file's target path folder will open.
Locate the file in the target path folder.
If the file is not present, the target path is inaccurate and likely the cause of the shortcut link error.
Locate the file in its correct folder.
Browse folders or search for the file by typing the file name into the "Start" menu.
After finding the file, open the properties of the shortcut link icon again.
Copy the file's correct path, from the containing folder's address bar, and paste it in to the "Target" box, replacing the incorrect link.
Another way to find a file's target path is by right clicking on the file and selecting Properties.
You can find accurate target information in the "Target" box, provided the icon is the original file icon and not a shortcut.
Aug 11, 2013 | Computers & Internet
Start
Jun 07, 2013 | IwantSoft Free Keylogger
Not enough space on target disc
If you are scanning in color choose JPG option as the file size is small. Delete unwanted files in the target location and create space.
S. Mohan
Dec 04, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
What is Target Overflow
Target overflow mean the file is too big for the target media (here CD/DVD). your ripped file can be just slightly oversized. If you still have problem with this, Let me know.. Good luck
Apr 28, 2010 | MicroBoards (DSRDVDD882) Burner
Cant save files from entrenet
if you want to save pdf files from internet, see just above the left side of pdf page , one save icon will be there. you can click on it and give the target place to save. if you want to save html , you can go to file option in the menu bar and click on save as and give target place .. Hope you will succeed...
Dec 06, 2009 | Computers & Internet
Can NOT transfer a jpg image from "picture file" onto a chip ken
Open the folder containing the image file.
With the SECOND (usually the RIGHT) mouse-button,
click on the file.
Point at "Send To" and a sub-menu will open, giving possible "targets".
Click on the target that references the chip, to copy the file.
Nov 06, 2009 | Microsoft Windows XP Professional for PC
.pst file not extracting, stating there is not
Some possibilites:-
1/ The zip file containing the .pst is corrupted.
2/ The target disk is not being correctly specified.
3/ The .pst file is very very large.
Nov 05, 2009 | WinZip 9.X for PC
Missing Manual and CD
Hi ! You can get the entire manual via pdf file on the Olympus website. I will attach a link here and will try to attach the pdf file itself!
http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?id=1224&fl=8
Also -- you can go to their Support then Software/Downloads for the stuff you are missing since you did not get the CD!
Hope this helps! :) Amy
PS -- it wouldnt let me add the pdf file - I'm sorry
Nov 11, 2007 | Olympus Stylus 710 Digital Camera
Monaco Systems Inc. Ezcolor Software & MonacoOptix XR Hardware (Bundle) for Mac, PC Logo
347 people viewed this question
Top Monaco Systems Inc. Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Monaco Systems Inc. Computer and Internet Expert? Answer questions, earn points and help others
