I bought a used Toshiba Satellite P35-S6292 laptop. Installed good hard drive, memory, fixed power inlet, and cleaned the heat sink. Started up and runs fine. Problem: "NO" sound at all except from fans. Any suggestions? Jim J.
  • amfriction Jul 28, 2010
    None of these suggestions worked and I never heard back the sender. Any suggestions?
    jIM j
    President:
  • 1,851 Answers
What operating system do you use? Are the audio drivers installed correctly? At this link you will find all the device drivers and the bios updates for the laptop. Report me the results.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jul 30, 2010
  • 6 more comments
  • amfriction Jul 30, 2010
    Just made a new install of XP Home and still no sound.
  • Stelios
    Stelios Jul 31, 2010
    Have you tried to install the drivers and the bios updatesI suggested before?
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
  • amfriction Jul 31, 2010
    My problem is not bios and drivers. I have reinstalled them 3 times and I even installed a new XP Home on a new HD which installs everything. All to no avail. It must be a motherboard or hardware problem with the sound device.
    Jim J
  • Stelios
    It maybe is a hardware problem but let's try all the possible cases. I want you to check 2 things for me.
    1. Right click my computer - Properties - Hardware - Device manager. Do you see any exclamation mark or question mark under sound devices?
    2. Get into bios (press del while the system is starting up at the black screens before the windows start up). Try to locate audio device and set it on enable mode (usually it's under the hardware tab or accesories or peripheral or something like that) Also note what is the hardware chipset (cmedia, realtec e.t.c.)
    Reply me the details.
    If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
    Thanks and regards
    Please kindly rate this solution
    Stelios
    there is no mention in the bios of sound or hardware defices. This is a toshiba satellite p35-s6292 laptop and you press F2 to get into the bios.
    i went into computer properties and there was no kind of mark under or around any of the items under sound or system devices.
    Jim J
  • Stelios
    Jim, sorry I forgot your laptop is Toshiba so F2 is the key to get into bios. Anyway you've got my point. Have you checked for audio using a pair of headphones or external speakers? The internal speakers may have been dead.
    Thanks and regards
    Stelios
    YES I TRIED EXTERNAL SPEAKERS AND GOT NOTHING EXCEPT STATIC WHEN I PLUGED THEM IN. THANKS FOR TRYING TO HELP. IT CANNOT BE SOFTWARE.
    JIM J.
  • Stelios
    Stelios Aug 01, 2010
    I think you have right. If you insist on using this laptop you can try with one small external USB audio card (take a look at these).
    Thanks and regards
    Stelios
    Guru:
  • 632 Answers
This is due to not having required sound drivers
The simple way of obtaining drivers if you are un-sure on the model of sound card, Then you can download Driverscanner from Uniblue.com
and scan for all missing drivers and Download the required drivers
It's useful software and will make sure all drivers missing are installed and they are kept upto date.
However if you can locate the sound card model/make you can go to the manufactures website and download the required drivers free of charge.
Posted on Jul 28, 2010
  • 2 more comments
  • amfriction Jul 29, 2010
    I went to Toshiba and Realtec and downloaded everything that anything to do with the audio and still no sound. When I try to play a song, media player says there is a problem with the sound device. Any more suggestions?
    Jim J
  • Simon Swales
    Simon Swales Jul 30, 2010
    yes you are missing the required drivers
    U cannot install random drivers, Just because you know the make
    there are specific models, Please download Uniblue Driver scanner
    Which will download the exact drivers Required
    Make sure you uninstall any sound drivers first before running driver scanner
    so you are sure it gets fresh drivers.
    I hope you are working for Uniblue. I installed ir paid them $29.95 and ran a scan. It said all drivers were ancient, as I suspected it would, a gimmick for idiots, so I downloaded all updates and installed them to "NO" avail also as I suspected. Now I am $29.95 poorer and still have a laptop with no sound.
    Jim J
  • Simon Swales
    Simon Swales Jul 31, 2010
    No i do not work for uni-blue However I use there driver scanner on many of my computers,
    Make sure you Uninstall any sound card drivers Then run a scan So that way the invalid drivers are removed, soon as you update drivers they will work again,
  • 472 Answers
  • Go to Control Panel / Sound & Audio Devices / Properties / Sound Playback – click on down arrow and check that the correct audio is selected. Typically the problem will be something “modem line 0 playback” has been substituted for the correct audio device.
  • Start / Control Panel / Administrative Tools / Component Services / a separate window will open – in left pane click Services(Local) / Scroll down to Windows Audio service / if the service is Disabled or Manual right click > select Properties > under Startup Type change to Automatic > click Apply > click Start > Reboot.
  • If you had the operating system installed already then click on start >> go to run and type devmgmt.msc >> under sound, video and controller or under others check if you see any name related to your sound card. Example : realtek, if you do then right click on it and click uninstall and then restart your computer.
Good Luck!
Posted on Jul 27, 2010
  • amfriction Jul 27, 2010
    I tried all three suggestions to no avail. Still no sound. Any more suggestions?
    Jim J
Toshiba P35 S6292 - LCD screen is all in coloured verticle and horizontal lines dancing around. Can work with notebook OK when on set on low screen resolution with large print. External monitor is fine. No...
if Display is OK in Low resolution then its the Graphic Chip Problem. take it to the service center. there they can replace graphic chip or the motherboard. best of luck
Jan 19, 2011 | Toshiba Satellite P35-S6292 Notebook
HI I Have a toshiba p100 laptop. i have had to re-install using recovery disc, the computer would start then shut down. with computer connected to external monitor it runs throught start up then ' say's...
I have the same computer. Recently, it started shutting down without noticed after an hour use, sometime earlier after heavy use. I did a Google search and find out that some Toshiba has overheating problem, and it was recommended to clean it the heat sink. If that is dirty the heat can not escape. I used a vacuum cleaner to **** out the dirt. It worked after so far.
A year ago, I had an other problem, I upgraded the memory, I used the Vista memory test. It did not reported errors. It became unstable, it would run for weeks without problem when for no reason would give file read errors, and all kind of problems,... So I created a bootable USB drive with memtes on it. My Toshiba booted to a linux op. and run the "memtest". It reported error on my newly installed memory. ... I used the recovery disk to have a clean start.
Also, during those times and sometime after, I've got those message, your window can be start, do you want to rollback to a previous point. Many time that message can be ignored, and just persist to start Window normally. Eventually it will, (if you know that your memory is working). I hope this helped.
Sep 27, 2010 | Toshiba Satellite P100 Notebook
Toshiba P35 s6292 need to retore to factory out-of-box state, how can I do that with no disks?
it is important to have the recovery disc to get that job done,but if don't have any of that pull out that hdd and load the operating system to any other laptop and install it back to its original unit and look for its drivers on toshiba website to have the drives functional
Jun 07, 2010 | Toshiba Satellite P35-S6292 Notebook
Upgraded my p35-S6292 laptop from 512gb to (2) 1GB
make sure that the two memory module have the same speed. say for example. if the first memory has a 667mhz speed the other memory should also be 667mhz. different memory speeds will cause conflicts.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 27, 2010 | Computers & Internet
Why have 1 colerfull line on my screen???
This could be one of three things
It could be the LCD Panel malfunctioning, the cable to the monitor has come loose or the video controller is malfunctioning.
Either way, this is not something you are going to be able to fix on your own. Your best option is to Contact Toshiba about warranty repair or bring it to a computer repair shop in your city.
Aug 17, 2009 | Compaq Presario M2000 Notebook
Satellite p35-s6292 shuts off
Try resating the memory and hard drive if it is easy to get to, if not you may need to take it to your locsl computer repair shop.
Good Luck.
Mar 15, 2009 | Toshiba Satellite P35-S6292 Notebook
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
P35 S6112 LAN WIRELESS IS NOT WORKING
STEVELAMBERT,
Double check your wifi switch position by taking a small flat head screw driver, and pop it loose and see if the post to the wifi switch is broken, if not properly reseat the wifi switch over the post. If that does not correct the issue, open the memory cover and reseat your wifi card.
PAeasop
Apr 25, 2008 | Toshiba Satellite P35-S609 Notebook
Computers & Internet Logo
98 people viewed this question
Alun Cox
David Payne
David Payne
